Download: Transforming an engine AC generator
How to turn a small engine generator?
This document helps to understand how it is possible to quite easily transform different types of motors into generators for small renewable energy applications at home.
More:
Transform an automotive alternator for a wind turbine
Forum Electricity supply
Forum self-construction and DIY
Download file (a newsletter subscription may be required): Transforming an engine AC generator
Read also:  Download: Motor Wheel TM4 by Hydro Quebec, Pierre Couture
3 comments on “Download: Converting an engine into an AC generator”
  1. Hello I have just come across your article which dates from about ten years ago and which is very interesting.
    Not being an electricity enthusiast, there is a calculation that I did not understand. (V3.UI = V3.400.2.8 = 1938VA). If you could explain it to me more clearly if he did not is not too late, because I would like to make myself a small all-electric generator and; plans for your first wind turbine if you don't mind.
    Thank you in advance.
    Mr Michel SELINGANT
    1. Hello Michel, almost 2 years late.
      This is the formula for calculating the apparent power, which is used to size the power of electrical equipment, the unit of which is the Volt Ampere (VA).
      The formula is S = V3 x U x I
      By V3 we must understand "root of 3" since we are talking about three-phase therefore 1,732
      With a voltage U = 400 and an intensity I = 2,8
      1,732 * 400 * 2,8 = 1939 VA
      1. Hello, I am contemplating your very interesting work, but I come up against one of your calculations for the values ​​of capacitors.
        Indeed reactive power = root of 1939 X 1938 - 1454 X1454 = 1231 VAR?
        indeed by following the mathematical priorities: (√1938 X 1938) - (1454 X 1454) we are very far from your result, can you deepen, hoping that you will receive my message.
        good to you guys
        please
        Eric
Leave comments
Your email address will not be published. Required fields are marked with *
