My turn to describe my editing.
The "victim" is a xantia 1.9L tubo diesel.
It shows 215 000 around the counter (hey it changes every day 😉
The plan is water doping. Very strong inspiration from Andre's Mercedes 300TD, but with less mechanical agility (and probably less patience as well Embarassed).
Cold water mist should be created by a homemade mini carb. Very inspired by PITMIX which has documented its work very well. In favor of simplicity, I do not foresee a spray system or the like.
The water settings, if possible, will be approached with small commercial plastic valves, designed either for aquarium, or for drip irrigation. I have several models to test.
For the moment, I have not planned to heat the water, to see. Rolling Eyes
Once I understand the behavior of the assembly, I hope to automate it with a small electronic assembly controlling a gasoline injection nozzle (but used for water) or a simple solenoid valve (I found some, coil 12V at 40EUR)
to follow, some pictures. As you can see, all the construction is made from recup ', second hand parts, only a few plumber fittings are bought new.
All the parts of the car which are modified come from scrap yards, and are then fitted. Using the car every day, I can't stop it while I make the changes. I must also be able to repair with the original parts in case of bad luck ...
