Chevrolet Tahoe
Good evening everyone,
Well as I had already said, I come by this post to keep you informed of my work.
I know in advance that it will not be easy (André warned me), but I want to, therefore I do.
I started to make a bubbler, (I keep it simple, because for me small carbs or aeros are a bit complicated) in stainless steel, in a 160 mm diameter tube, with a "conical cap" on the top and anti-rising water deflector inside. I soldered the whole with silver solder (I have nothing else) and apparently it holds and it is hermetic.
I plan to put a 32 mm diameter copper suction tube, pierced with small holes for bubbling, and feed this bubbler with a brake switch and washer pump (classic no?). That's roughly for the bubbler.
For the reactor, I think of putting 2 (1 in each exit of esc) while leaving the diam of origin. As the place I spotted are straight parts, I am thinking of installing them at an angle to have the entry and exit opposite and thus avoid elbows. I don't know if being skewed matters or not? If anyone can tell me. I intend to solder the reactor to the exhaust tube, silver solder or MIG? What do you think ?
Read also:  Water injection on Renault 21
For the aspiration between the bubbler via reactor, via intake, I will install it just before the venturi which is already used for LPG, we will see… I have not yet found if it existed on this model, an EGR valve , but I don't think so, it is from 1999.
For the photos, I would make an attempt, but it is not won, because I am bad at computers.
Nofy (dream)
Read more: Click here to go to the corresponding editing page
Other assemblies and experiments with assemblies of Pantone engines
Leave comments
Your email address will not be published. Required fields are marked with *
