Chemtrails? oooouups I said nothing!
ps: without laughing, yes this method is detailed at the beginning of this topic
Geoengineering: cool the Earth against warming
- Moderator
- x 11062
- sen-no-sen
- Registration: 11/06/09, 13:08
- x 749
Christophe wrote:Chemtrails? oooouups I said nothing!
Chemtrails are conspiratorial theory, the spreading in question will be done either with sulfur dioxide which will not be seen directly, or with particles which will remain whole months in suspension, as is the case with volcanic dust.
By cons in both cases the blue sky will give way to a clear gray sky.
The "chemtrails" (contrails) persist at best only a few hours and once dissipated gives way to a very blue sky, proof that this thesis is "smoky" ...
"Engineering is sometimes about knowing when to stop" Charles De Gaulle.
If it is possible to limit the most immediately unfavorable factor to "acceptable" living conditions (with the vagueness that this adjective involves!), This will only bring the contradictions of the other factors to a higher level and defer the results. real solutions which require a radical questioning of the model.
"Please don't believe what I'm telling you."
- Registration: 28/09/09, 17:35
- x 554
Enriching the Southern Ocean with iron might not be so effective
What would be the response of the marine ecosystem to natural iron enrichment? More complex and less effective in the long term, from the point of view of carbon dioxide storage, than previously thought, according to a new study carried out in the Southern Ocean.
15/11/2014 at 11:27 am - By CNRS
http://www.futura-sciences.com/magazine ... ace-56039/
The most trivial truth is that no one has a clue what a large-scale intervention (one of those planned) would actually produce, or what interactions would result inside it. a system far too complex to be sufficiently understood.
Unfortunately, blinded by repeated successes, the mad desire to surrender "master and possessor of nature"* remains the leitmotif of our societies: they (successes) constitute the" fragility of power ", as described Alain Gras or "disabling assets" according to Bertrand Meheust.
*Descartes
*Descartes
- Moderator
- x 11062
Re: Geoengineering: Cooling the Earth Against Global Warming
The new "idea" of some scientists ... It's obviously not an April Fool's Day ...
http://www.lepoint.fr/environnement/dix ... 9_1927.php
No comment!
Ten million machines to refreeze the Arctic
According to CNN, researchers have found a theoretical solution to limit the melting of the ice floe: build 10 million wind pumps. (...)
No comment!
- Registration: 17/03/14, 23:42
- x 1525
And with a septic climate at the head of the USA we did not leave the hostelTheoretically, this plan is doable. On the other hand, it will be necessary to convince the United States and Russia whose policy concerning sustainable development is almost non-existent.
And finally, we must above all reduce our greenhouse gas emissions drastically. If these emissions do not decrease, this plan will only have one temporary effect. http://fr.newsmonkey.be/article/16122
- chatelot16
- Registration: 11/11/07, 17:33
- x 264
since we left in such nonsense ... rest assured! when we see the number of air conditioners installed all over the world it will eventually cool the earth
as sure that a sailor in his boat will advance his boat by pushing the mast ...
also on that 2 and 2 are 5
- Moderator
- x 11062
Arte Documentary on Geoengineering:
- Moderator
- x 11062
Updated video
Back to "Climate Change: CO2, warming, greenhouse effect ..."
Who is online ?
Users browsing this forum : No registered users and 124 guests
