A microbial hydrogen-producing fuel cell
Microbial fuel cell (MFC) for hydrogen production
A team from Penn State University and the company Ion Power (Delaware) developed a Fuel cell microbial (MFC) allowing both to degrade organic matter and to produce hydrogen.
Conventional MFCs (developed to offset the costs of wastewater treatment) generateElectricity supply from the oxidation-reduction reactions involved in the processes of degradation of organic waste by bacteria.
The new device, called BEAMR for BioElectrochemically-Assisted Microbial Reactor, is based on the use of hydrogen produced by bacterial fermentation. Under normal conditions, this process converts carbohydrate compounds into a limited amount of hydrogen and acetic acid-like residues. By applying a very low voltage (around 250 mV) to an anaerobic MFC, Bruce Logan and his colleagues have however succeeded in increasing the electrochemical potential of bacteria and therefore their ability to break down molecules by-products of fermentation. They were thus able to recover in the form of gaseous hydrogen more than 90% of the protons and electrons resulting from the oxidation of acetate by bacteria. The hydrogen released is itself the fuel for a cell which produces the applied voltage. This simple stimulation makes it possible to extract four times more hydrogen from biomass than fermentation alone.
Read also:  Patents for ecology
In theory, the principle tested by researchers is not limited to carbohydrate compounds; it could be effective with any organic material biodegradable soluble.
Learn more about forum energies
NYT 25 / 04 / 05 (Fuel cell sweaters hydrogen out of bacteria)
Leave comments
Your email address will not be published. Required fields are marked with *
