Download: Rotex Sanicube, the innovative hot water tank
Share this article with your friends:
ROTEX Sanicube, a water balloon accumulator Hot sanitary and innovative health
Summary and principle.
The ROTEX Sanicube enables a physical separation between drinking water and water accumulation (heat buffer) via an exchanger "Instant heat".
The ROTEX Sanicube is a combination of a hot water storage tank and instantaneous water heater.
Heat strictly speaking is not stored in the drinking water (as in a conventional water heater) but in the storage tank water which is physically separated by a heat exchanger.
The volume of water is relatively low: 19 80 to liters as the ball type. The total volume of accumulation is to him 300 500 liters. The amount of heat that can be accumulated and drawn off depends.
During the first commissioning, the vessel of the balloon is filled only once. This water storage is only used to heat build-up, it is not changed or used. It is a volume called "dead water".
More: Mounting and installation of a Rotex Sanicube
Download file (a newsletter subscription may be required): Rotex Sanicube, the innovative hot water tank
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
