Download: biodiesel production method or diester
Share this article with your friends:
biodiesel synthesis by transesterification or how to make your own diester
Summary
1. Overview
2. Chemical equation of the transesterification reaction
3. Laboratory biodiesel synthesis protocol
4. Determination of the physical characteristics of the synthesized biodiesel
1. Overview
The transesterification is the classic technique of biodiesel production.
This is a process in which vegetable oils, animal fats or microalgae based oils are cold mixed with an alcohol (ethanol or methanol) in the presence of a catalyst (sodium or potassium hydroxide) .
Processing oils or fats ethyl or methyl esters can reduce the molecular weight to a third of that of the oil, reducing the viscosity of a factor of eight, to reduce the density and increase the volatility.
Physical properties of the ethyl and methyl esters obtained in the transesterification reaction are then similar to those of diesel oil origin.
Learn more, ask questions or share your experiences: recipe for its biodiesel
Download file (a newsletter subscription may be required): Biodiesel production method or diester
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
