Download: GlassX, ultra high thermal performance glazing
Share this article with your friends:
A transparent thermal coating ultra high performance: the Crystal GlassX
GLASSXcrystal intègre 4 system components in one functional unit: Transparent Insulation - protection against excessive heat - energy transformation - thermal collector.
A triple insulating glass structure offers excellent thermal insulation with a U value of less than 0,48 U = W / m2K.
A prismatic glass placed in the space between the panes reflected outward when the summer sun is at its highest, with higher incidence angles to 40 °. For cons, the winter sun crosses in its full intensity sunscreen.
Central to GLASSXcrystal is a thermal accumulator module that absorbs solar energy and releases it with a time lag in a pleasant radiant heat. as storage material using a PCM (Phase Change Material) in the form of a salt hydrate. The accumulation of heat is carried out by the fusion of PCM; for cooling, the accumulated heat is released again. The salt hydrate is welded hermetically in polycarbonate containers.
Within the premises, the element is closed by a safety glass in one window 6 mm, the arrangement can be changed.
More: energy storage phase change by example and Crystal GlassX
Download file (a newsletter subscription may be required): GlassX, ultra high thermal performance glazing
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
