Download: Power Combustion of hydrogen and radicals generated by a cold plasma
Share this article with your friends:
Synthesis 35 pages PLASMHYRAD project CNRS-Orleans GREMI entitled:
« Combustion assistée par hydrogène et radicaux générés par un plasma non thermique »
The first tests were conducted GREMI with a tubular laboratory reactor comprising two parallel electrodes. The power supply used is a transformer voltage booster magnetic leakage (220V / 15kV) to 50 Hz. The first goal was to define the air methane mixtures which may be used given that the methane concentration limit is defined by the HEL which is 15% and the carbon deposition is forbidden to allow motor operation. The tests were conducted at atmospheric pressure.
Download file (a newsletter subscription may be required): Combustion-assisted hydrogen and radicals generated by a cold plasma
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
