Download: Calculation of a solar exchanger
Share this article with your friends:
Estimation of surface and length of a solar exchanger in simple copper tube (without fins) immersed in a solar thermal buffer
.xls spreadsheet (compatible OpenOffice) for determining the surface and length of a solar exchanger for solar thermal pad or ball. This exchanger is the primary solar exchanger, it is mounted side primary circuit. This is the exchanger found down the balloons solar market.
Settings:
- Surface of a sensor
- Number of sensors
- Total area sensor
- Solar power per m²
- Total Solar Power
- Delta T °
- Pipe diameter in mm
- Exchanger coefficient of performance
Results:
- Serpentine Area required
- Coil Length
Learn more and ask your question: construct a heat exchanger made of copper et example of a solar wood house using such exchanger
Download file (a newsletter subscription may be required): Calculation of a solar exchanger
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
