The hydraulic wood stoves
Share this article with your friends:
Hydraulic pellet stoves or stoves Log boilers or stoves Thermo
See other types of wood stoves
They are based on exactly the same principle as pellet stoves but also have a heat exchanger with water. They are designed to be connected to a hydraulic circuit (central heating and / or hot water DHW). They can heat the room, water or 2 same time. They are a good solution to prepare DHW in winter.
They are, in fact, stoves hybridized between the boiler and the pellet stove, hence their name 2ième: boiler stove.
More: discussion on the choice of a hydraulic wood stove
EDILKAMIN-stove
Thermo-Edilkamin Charme of 16kW. Strongly resembles a pellet stove without hydraulics.
There are also but it is rare (usually it's self building see links below) logs inserts and stoves with hydraulic circuit. Here is a model from Rika, Austrian manufacturer "high technology":
rika aqua tavo
Section of a log burning stove hydraulic model Rika Tavo Aqua. 4000 approximately €.
Caption: combustion chamber lined with chamotte (1) allows high hot gas temperatures preventing fouling of the boiler. Exchangers hydronic heat (2). thermal flow security (3). Go (4) and output of the flue pipe above / behind (5).
Sensor (6) thermal security. Sensor of the boiler pump group back (7). revision hole (8) easily accessible for cleaning (if necessary). own panoramic glass (9). Control of the combustion air (10). Return of elevation Group (11) (optional). 30% of radiant emissions (12) in the living quarters.
Learn more about the logs in hot water fireplaces:
- Heat recovery system into an existing wood stove
- Other Assembly woodstove with hot water coil
- Insert hydraulic Vouzier
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
