rotary engine sorting lobique
Share this article with your friends:
For better use of natural energy flow Author and inventor Pascal HA PHAM
rotary engine sorting lobique forums
rotary
FIG 1: photo inside a small annular piston engine "tri-lobique" displacement 117 cm3
Abstract: Background and purpose of the invention.
Historically, nature disperses a lot of energy to the surface of the planet, yet man uses only very little power contained within this multitude of streams. These flows are varied, different, fleeting, fickle, capricious and violent, how to better use?
Fringes, whole fields of natural energy are now "fallow" very low energies and vulgar drafts, very brutal and unpredictable storms, very strong Saharan ascendants, or irregular in diet and / or nature of the volcanic geothermal energy smoothed slow streams, rapid torrents ... solar power, marine power, he all this will one day be made more available to consumers?
Both individual production than for a heavy and mass production, it is urgent to organize better result in our quest, or rather our human bulimia, but insufficiently shared, domestic energy.
Faced with unreasonable management, excessive and even risky fossil fuels and nuclear energy, there is room to roll up our brains, to innovate, to invent, to test new concept adapted machines. Better use of all these riches which disperse: quickly invent the generic machines need to access the immense natural generosity.
1. Introduction, Questions
Some basic questions: What would it take to do better the challenge of 21eme century, the challenge of energy "better convert the entire range of natural energy flow" ...?
What simple machines which source? What criteria of sustainability? What scope of operation? Possible additional systems required for water supply and or formatting the natural flow? What criteria to characterize the simplicity and the required extension of the machine, the machine set + supply system? Locating energy zones of the planet? These areas are they to areas of high population density, so consumption? Realism interconnections? On such projects, what should be the contributors? How to extract the pool of existing inventions simple machines, efficient and versatile tomorrow? How effectively and efficiently innovate paying much more attention / acuity natural energies?
I will try to answer ... solutions primers primers.
2. Study of existing: the current generic machines
How to meet our current machines in the quest for renewable energy?
These machines are generally single type of fluid (compressible and incompressible) and little or not accept operating irregularities (supply irregularities, rapid change of engine speed, reversing), perimeters and environments are still too narrow, too specialized, too rigid. Faced with a large nature diverse, changing what have we already implemented?
a) Wind turbines
those useful for grinding grain or up water have been somewhat forgotten ... only the wind to produce "massiquement" electricity have recently had a strong development.
They become monstrous because the man wants the powerful and function is effective with winds in excess 15km / h and less than 80 km / h.
Outside this range do not produce or are in a critical risk area of ​​operation. Vast wind fields are under construction and in operation.
b) Hydraulic turbines
The energy of falling water is used for a long time, it must nevertheless be seriously formatted through weirs, dams or installing gigantic dam type for that output of a turbine system, for example of the type "Pelton "(operating at high pressure), can then drive an alternator and produce electricity.
Beyond these well-known 2 generic machines, are there actually other with also popularized use?
I think not ... yet the hydraulic ram pump Montgolfier was admirable generic machine invented and designed to 18eme century and strangely forgotten nowadays.
The tidal power plant of Rance is a special case, a system and not a generic machine.
Other machines designed for other operating conditions can also be adapted to machine convert natural flows: internal combustion engine, steam piston connecting rod crank, gas turbine, vane motor, hydraulic motor gear Or other. However, the food in adaptation with the natural fluids often go even more complex and thereby they become specialized and require specific operating conditions and very stringent. Outside their narrow scope, they no longer work or appear extremely low yields: administer a natural fluid pressure in the combustion chamber of an internal combustion engine while it is at bottom dead center. He has no traction on a relatively large angular aggregate.
rotary engine, the sequel
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
