water injection assembly on a tractor TN75 Turbo Diesel
Share this article with your friends:
A modern tractor modified by doping in the water!
Keywords: pantone, engine, water consumption, reduce, reduce, how, map
Here is the testimony of a change on a modern tractor New Holland 75 hp Turbo Diesel. That page comes Site Quanthomme
The testimony
Our reactions are inserted in italics.
Here is a new tractor modified as 3 Mérindol tractors (The 55, 56 and 57 to see in the base site http://www.quanthomme.org )
The differences are that it is recent (2002) and turbo.
This is a New Holland TN75, 4-wheel drive.
The adaptation was made in 2h30 like the others. It "bubble" from 1000trs / min and it became quieter after 30 min walk. On the other hand no big differences to the fumes because it is recent and did not smoke almost before, but there will be less odors in the greenhouses.
Regarding Mérindol tractors (55, 56 and 57 cited above) The Massey 140 3,2 now consumes l / hour at full load (between 6,5 and 8l / h of origin after Massey dealership) and there is no more hot smoke (test whiter than white cloth! ) ditto for the Ford 2000.
After the first week of use:
Consumption: 219 41,4 h liters of pretty intense work, plowing bisoc to 6,5 7 km / h, m Mulch 2,5, 2 under soleuse body. (5.3 or l / h)
For equivalent work, according to the seller, the tractor should consume 7,5 l / h.
This tractor, fully loaded (laboratory test bench) must consume just under 9l / h.
This value is underestimated: a diesel engine has a specific consumer 5 bhp-h / l, an engine 75 CVs must consume 75 / 5 15 = l / h at full load.
Note also that the system consumes just over 2 liters / hour.
our remarks : This testimony seems to prove that the system would not work only on old engines but only a passage on the test bench with exact knowledge of the load and compared with the original data could confirm these results and give them a scientific rigor which is so lacking in the development process!
More:
- Forum for exchange of experience on the water injection
- Analysis of tractors
- The engineer's report on the Pantone motor
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
