Parts List for a change pantone
Share this article with your friends:
List of parts necessary to achieve your first pantone engine.
Read installation instructions part 1
This list is obviously not exhaustive and will depend primarily on your type of assembly and engine.
On some engines only
adapter plate steel 1 / 2 "with 4 allen nuts recessed head 3 / 4" and a steel disk 12 "
Pour le « réacteur-échangeur »
1 - black tube 16 7 / 16 "x 1 / 2" (cut and threaded)
1 - black pipe fitting 12 "x 1" (painted)
1 - 12 steel rod "x 1 / 2"
2 - 1 reducing tees galvanized "x 1 / 2" x 1 / 2 "(Ward - the best)
2 - sump Copper Washers 22mm / 7 / 8 "
1 - galvanized pipe fitting 2 "x 1 / 2"
1 - galvanized pipe hanger of 1 "with bolts and nuts
4 - galvanized pipe fittings 1 1 / 2 "x 1 / 2"
1 - galvanized pipe fitting 3 "x 1 / 2"
4 - ball valves of 1 / 2 "NPT (B & K - best)
1 - silent NPT galvanized 1 / 2 "
3 - galvanized pipe Tees 1 / 2 "
2 - reducing rings of galvanized pipe 1 / 2 "x 1 / 4"
1 - paint box (grill) high temperature
27 copper tube "- 1 / 2" (* 5 / 8 ")
2 - Male rings flared brass 1 / 2 "NPT / 1 / 2" (* 5 / 8 ")
2 - flared bolts brass 1 / 2 "(* 5 / 8")
For the bubbler evaporator
1 - can of antifreeze 4 or 5 liters
4 - clamps galvanized pipe to 1 / 2 "
6 - Vinyl pipes transparencies 1 / 2 "ID (cut into 2)
2 - galvanized pipe fittings 3 "x 1 / 4" (cut into 2)
4 - rings galvanized washers 9 / 16 "(and 1 / 8" thick)
1 - galvanized pipe elbow de1 / 4 "
2 - galvanized pipe fittings 3 / 4 "x 1 / 4"
1 - galvanized pipe connector 1 / 4 "
1 - water pipe copper 10 3 / 4 "x 1 / 2"
1 - Copper pipe plug 1 / 2 "
2- copper pipe adapters 1 / 2 "x 1 / 4" NPT
More: Forum pantone fixtures
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
