Recycled jet stream
The idea is madly in the wind. This involves using the jet stream which blows between 4 meters and 500 meters in altitude, all around the globe, to produce electricity by means of flying wind turbines. Like a kite, they will be secured to the ground by an ultra-resistant Vectran cable surrounded by two aluminum wires which will carry a current of 15 volts to a ground station.
Concept inventor Bryan Robert of Sydney University of Technology plans to equip each wind turbine with four 40-meter-long rotors made of very lightweight materials. They will first serve as a propeller to bring the machine to the desired altitude, then the blades will begin to turn on their own, moved by the jet stream. Bryan Robert calculated that a wind farm of 600 of these machines with a power of 20 megawatts each could power two Chicago. After testing models, he joined forces with three other engineers to create a start-up in California called Sky WindPower. They plan to manufacture a 200 kilowatt prototype within two years, provided they find the $ 4 million they need.
Read also:  Ecobilan of a car: would the Dacia Logan dci be cleaner than the Toyota Prius hybrid?
Problem: these flying wind turbines could constitute obstacles for planes, but the inventor retorts that there are about fifteen balloons in the upper atmosphere without any accident having ever been deplored.
Source
Leave comments
Your email address will not be published. Required fields are marked with *
