Summary document on the electrification-ionization of water vapor applied to the Pantone process in doping with water. By J.Rochereau.
Keywords: QED, DEQ, Quantum Electro Dynamics, Radiation, UV, Sonoluminescence, water doping, heat engine efficiency, ionization, hydroxyl, hydronium.
Introduction
Here is a document of my own to offer an explanation for the drop in consumption observed with the water doping.
As an automotive engineer, the mystery of this system is a constant stimulus for me ...
One more theory will you tell me… It is true that between cold fusion, plasma, and more recently “the integral conversion of heat into mechanical work”… everything (or almost) has happened…
In contrast to the preceding, My explanation is based on the observations made by the people who use the water for doping, patents for inventions Recent past scientific work, and scientific work in progress in laboratories.
Christophe Martz, the webmaster of this site and I have tried to ensure that the document is quite readable and affordable for the greatest number. We hope that as many people will read it.
Otherwise, All cited documents and work is accessible on this site. And external sources are always specified when they need to be!
Document Summary
Briefly, the explanation of which the development is proposed, based on a drop in consumption only produced by the action of water vapor on fuel, due to its electric charge.
According to the pH of the water used, steam is more or less electrically charged and all experimental findings coincide in this hypothesis.
Learn more? Download the .pdf documents
Christophe Martz, following different assumptions from the beginning, is certainly convinced (at least in part) by one.
Maybe we are wrong ... but maybe not because the experimental similarities are too numerous to be due to chance. The secret of the pantone engine may therefore be there!
Anyway, we hope that many people will try to experimentally test the validity of this explanation.
If the manipulations confirm the theory even more, it will obviously "remain" to optimize the thing with or without the help of the engine manufacturers ...
J. Rochereau the January 20 2007
Learn More
- Download the document “A credible explanation for water doping? "
- Debate on forums
