Injection of water into the Daimler Benz engines on aircraft Messerschmitt
Share this article with your friends:
Some explanations on turbocharging and injection of water or peroxides Daimler Benz on Aeroplanes 2ieme World War.
Keywords: engine, aircraft, Luftwaffe, overeating, limits, ceiling, injection water, octane, compression rate, improve, Merlin
The Daimler-Benz DB engine 605
Summary
1) Introduction
2) A quick technical basic principles of DB 605:
- The basic concept and its performance
- The over-supply system
3) Chart performance and comments on the derived types: DB605A-, AM, AS, ASM, ASC, D, D-2, DB and DC.
4) Comparison with the Merlin engine two-stage compressor, direct rival DB 605
Introduction.
The Daimler-Benz DB 605 engine was improved deemed DB 601 and made his service on the same equipment that the latter: the Messerschmitt BF BF 109 and 110. The version used 605 from 1942, it gave more power to the aircraft to climb to a higher altitude and with increased load capacity. Just like me 109, 605 DB proved essential during the war. It was gradually improved to remain competitive and, fortunately for the Luftwaffe, there was a good potential for development, although its reliability suffered a bit. War always required more power and better performance at altitude. The DB knew 605 meet these constraints through the use of a fuel with a higher octane power, resulting in better compression ratios, more power and acceleration, better power-on and injecting a non-explosive mixture of water-methanol or peroxides. Thus, the final defeat of the Luftwaffe in 1944 can not be blamed on a failure of the engine.
Unfortunately (from the Germans point of view), the best-performing versions were put into operation in 1944 on "big" devices when gasoline was already lacking, and mostly driven by inexperienced beginners. They were completely crushed by the allied forces.
The basic technical principles of DB 605
The V-12 60 degree of spilled pressurized cooling - bore: 154mm race: 160mm, total displacement: 35.7 liters - compression ratio: 7.5 / 7.3 (octane 87) 8.5 / 8.3 (96 index) b - length: 2303mm, height: 1050mm, width: 762-845mm - dry weight: 730-745 kg, mounted weight: 764-815 kg - 4 valves per cylinder, 1 camshaft overhang - direct injection - mechanical compressor variable speed (one floor) with a hydraulic clutch which fitted the barometric pressures at altitude (the 605L DB had a compressor stages 2) - Board: max 2800, uphill: 2600, maximum cruise: 2300 - performance: 1435 2000-hp (0 altitude) - evaluated in altitude ascent condition: 5.8 - 8 km (except new DB 605L) - several versions were equipped for system use MW-50 or 1-GM
The system of on-feed ..
Compared to engines with turbo compressor or two-storey and two-speeds of the Allied forces, developed by Daimler-Benz DB 605-a-floor is outstanding.
For comparison, the two-stage Merlin engines rose at an altitude of at 5.8 7.9 km. In 1944 altitude battles, the performance of the DB 605 rivaled those of Merlins series 60 and 70, Spitfire and Mustang.
While conventional mechanical on-feeders consisted of one or two compressors controlled by a transmission in two floor, Daimler-Benz used an ingenious hydraulic clutch adapted to barometric pressure changes which adjusted the speed of the compressor and consequently the engine supply the needs of the current altitude.
The conventional method causes a relative loss of efficiency as the unit has reached its cruising altitude because the compressor uses energy to overeating. A graphical representation of the performance of this type of engine according to the altitude of the aircraft would show a line in "sawtooth" performance in first gear would rise with altitude up to the ideal altitude for that speed, then the yield would fall until the second gear engages and the yield increases again up to the ideal altitude. The Daimler-Benz system is more flexible. The graph will show a gentle curve.
Chart performance and comments.
Click to enlarge
Source: Mercedes-Benz AG, Archives, Stuttgart, Germany. * = The DB 605D has not entered into service before the spring 1944-109 10G me.
Comments.
Subcategories Me 109 were delivered with the following engines:
-Me 109g-up G1 4: 605-DB 1A
-Me 109G-5 / 6 G-DB-605A 1, AM, AS, ASM (ASB, ASC?)
-Me 109G-8: 605-DB 1A AM
-Me 109G-14: 605-DB 1A, AM, AS, ASM (ASB, ASC?)
-Me 109G-10: DB 605D, (D-2?) DB, DC
-Me 109K-4: DB 605dc, ASC
As the table shows, the different subcategories gave very variable results. Thus, the performance of the Me-109G 6 varied enormously since this model was equipped with many engines installed upon availability of the moment. The DB-605A 1 was still used at the end of the war.
About the MW-50
MW-50 (water / methanol 50 / 50) was injected through the air intake and served as an anti-explosive, allowing more below the ideal altitude thrust. The evaporation of water also cooling the supply air, thus increasing the weight of food.
Limited by over-supply system, the MW-induced 50 as maximum yield began to decline in 1.5 - 2 km below the ideal altitude, becoming inactive above this altitude (compare eg DB 605A -1 and AM).
Maximum usage time: 5 10 in minutes.
Constraints shortening endurance flying and life of candles, the additional weight of MW-50 tank and pipes. The majority of sub-categories of Me 109 1944 / 45 was equipped for the use of MW-50.
About GM-1.
Another way to increase the performance was the GM-1 (Göring Mischung 1).
It consisted in injecting nitrogen dioxide (nitro) in the on-feeder above the ideal engine altitude.
Nitrogen was used as "carrier" oxide oxygen to increase the high-altitude performance (using pure oxygen being too volatile).
The effect was phenomenal, instantly increasing the power of 25 - 30%.
GM-1 was used by the flight of groups specialized in high altitudes from 1941. Volume and excess weight were the main constraints of this system and the additional over-feeding was generally seen as more efficient.
Comparison with Merlin 2-floors.
We do not present here scorecards Merlin engines because we lack precise data (our sources ( "Allied aircraft piston machines" Graham White and "Jane's fighting aircraft of world war II")
Given the age of the design of Merlin and the small number of improvements which he was subject, this two-stage engine was a beautiful machine. Compared with German engines, the Merlin was lighter thanks to the relatively abundant use of light alloys.
When comparing the returns, we must bear in mind that the Allies were well supplied with high octane gasolines indices (100 / 130 / 150). The Germans had to settle with 87 indices 92 or 96, the highest indices species are extremely rare.
Merlin 60 series were commissioned at the end of the summer 1942, in perhaps around the same time that the DB-605A 1. The performance of Merlin 60 high altitude were higher than those of DB-605A 1. This superiority lasted until 1944 when subcategories AS and D went into service. These equalized and exceeded the performance of high altitude Merlin (Rolls-Royce and Packard), with the exception perhaps of Mark 70. But when the GM-1 went into action, the advantage was definitely DB 605.
The 605 DB had good performance at low altitude, especially at sea level (see paragraph on over-supply systems). From this point of view, the DB-605A 1 was superior to Mark 61, 63, 66 and 68 Merlins. The superiority of the last DB 605 at low and medium altitudes was very clear when they used the MW50: Methanol / Water 50 (versions AM, ASM or high octane and GM1 (DB versions, ASB) or high octane and GM1 and 50-MW (DC versions, ASC).
Appreciation of a partnership: 605 DB mounted 109G Me and K
The arrival of Me 109 G coincided at nearly with the position of turning to the Germans: the Allied offensive in Africa and Stalingrad. The Luftwaffe was facing a vast numerical superiority, aircraft and enemy pilots were becoming more powerful and soon came the Götterdämmerung in defense of the territory of the Reich, which deprived the Luftwaffe of its men, equipment and fuel.
If there is a symbolism in this, we will not move forward. But much has been written on hatred carried to G (Gustav) - a bit of blisters everywhere destroying aerodynamics and appearance of this aircraft, it was heavy and difficult to maneuver, a step backwards compared to the sub- class F. However, many of the biggest "Experten" killed a majority of enemies Gustav.
The 109G me was, like previous models, a good interceptor during the fighting. He was with features for low speed flight, high ceilings and equipment from light to ensure good, even phenomenal rise, a rapid acceleration in the flight levels and the ability to make maneuvers supported . The normal equipment, although relatively small, was extremely accurate due to the central location of all the guns.
In short, it was a good fighter and classic.
The increased weight of course with the introduction of more powerful, heavier engines, which required strengthening of the structure and the old easy handling suffers a little.
Although it can be compared to new aircraft ally in terms of speed, climb and altitude ceiling, it was during the fighting in 1943 1945 (against the day bombers and their escorts), that the shortcomings in the design of these interceptors which dated from the middle of 30 years.
Equipped as a bomb with 2 20 mm cannons under the wings, the Me-Gustav became difficult to use. This and the fact that the high altitude performance was much better than the FW 190, Gustav took, initially, on top escorts allies. These air battles took place at high altitude and high speed, and at those speeds the control of Gustav was very difficult (because of the return of control forces: the sensitivity and effectiveness of controls were virtually nil and directional stability )
With the loss of his Maneouverability the Gustav became a mediocre interceptor and being a lightweight fighter, the Gustav could not concurencer new American hunters.
Original version :
List of happy.
1) Introduction
2) A short note on the basic technical aspects of the DB 605
-Basic layout and performance
-the supercharging system.
3) Focusing on the single-engine applications of this engine, performance charts and commented-ries on the sub-type Following are presented:
-DB 605A-1, AM, AS, ASM, ASB, ASC, D, D-2, DB and DC.
4) Comparison with the two-stage Merlin engines - Direct the rival of the DB 605. 5) Appraisal of a partnership: the DB 605 powered 109G Me and K.
Introduction.
The Daimler-Benz DB engine 605 Was an up-boron running faster development of the famed DB 601 and served the Sámi hand aircraft type as icts predecessor: the Messerschmitt bf bf and 109 110. Introduced in 1942 it presented the basic fighters with more power, better altitude performance - and Higher weight. As the Me 109 Remained a mainstay Throughout The war - So did the DB 605. It was Progressively Developed to stay competitive, and luckily for the Luftwaffe It Had Good develop-ment potential, ALTHOUGH reliability Suffered Somewhat. The war Demanded ever more power and - in the west - still better altitude performance, and That Was challenge met by the DB 605 through the use of higher grade fuel, higher compression ratios, higher boost Pressures, better supercharging, and injection of anti- detonant water-methanol and oxygen carrier nitrous-oxide. As it turned out, the final demise of the Luftwaffe fighter strength in 1944 Hardly can be blamed on this engine the primary fighter of the Luftwaffe. Sadly from a Luftwaffe points of view, When the thin high-power, high-altitude cam versions into Service During 1944 They Were able to use in an overstretched airframe piloted by inexperienced rookies, Who starved of fuel Were completely Call overwhelmed by superior allied forces.
Basic technical aspects of the DB 605.
(This description and The Following performance will be tables using metric measurements.) - 60 degrees inverted V-12, pressure-cooled - boron: 154 mm, stroke: 160 mm, total volume: 35,7 liters - compression ratio: 7.5 / 7.3 ( 87 octane), 8.5 / 8.3 (96 octane) - length: 2303 mm, height: 1050 mm, width: 762-845 mm - dry weight: 730 - 745 kg, built-in weight: 764 - 815 kg - 4 valves per cylinder, 1 overhung camshaft - fuel injection line - single-stage variable speed mechanical compressor driven via a barometricly controlled hydraulic clutch (the DB 605L had a two-stage compressor) - rpm max. 2800, climb: 2600, max. cruise: 2300 - Performance: 1435 - 2000 hp at sea level - rated in altitude climbing condition 5.8 - 8 km (again excluding DB 605L). - Several versions ecquipped to use MW-50 1 gold-GM
A note on the supercharging system.
Compared to the two-stage two-speed and turbo-powered engines of the western powers it is im-pressive what Daimler-Benz could achieve with the single-stage DB 605. By comparison the two-stage Merlin engines had a rated altitude ranging from approx. 5.8 km to 7.9 km. At the battle of 1944 the performance of the 605 rivals that of the high altitude Merlins 60 and 70 series of the Spitfire and the Mustang. While the conventional mechanical superchargers are driven by a two-speed gear, Daimler-Benz uses a barometrically controlled hydraulic clutch which causes the compressor to run at a higher altitude. The conventional method of production in a relative loss of efficiency. A graphic presentation of the output of a high-altitude production of a high-speed motor vehicle. altitude is reached. In comparison, the Daimler-Benz system is more flexible. A graphic presentation would show a smooth shallow curve. A source of efficiency with this system being progressive heating of the oil pressure in the clutch builds with altitude.
Performance charts with comments
Source: Mercedes-Benz AG, Archives, Stuttgart, Germany. * = The DB 605D Did not enter the service up to spring of 1944 with the advent of the Me-109G 10.
Comment.
The Me 109 sub-type Were Delivered with The Following power trains:
Me 109G-1 4 through G-DB-605 1A
Me 109G-8: 605-DB 1A, AM, (others?)
Me 109G-10: DB 605D, (D-2?), DB, DC
Me 109K-4: DB 605DC, ASC (others?).
As the table shows, the different sub-type gave very different performance, the performance of the THUS Me 109G-6 varied a lot as this model Was powered by a whole ranks of engines DEPENDING ON availoability. The DB-605 1A Was still installed to the very end of the war.
A note on MW-50.
MW-50 (water-methanol 50 / 50) Was injected into the air-intake and served as an anti-detonant ALLOWING Higher boost to be used below normal rated altitude. The evaporating water aussi cooling load the air THUS Increasing the weight of the load. Limited by the performance of the supercharger the MW-induced 50 max. Declining output Began 1.5-2 km. below normal rated altitude up to it est devenu impotent at and above the normal rated altitude (compare for example DB 605A-1 and AM). Max. continous use: 5-10 minutes. Penalties: drasticly shortens flight endurance and spark-plug life, added weight of MW-50 tank and piping. Most sub-type Me 109 from 1944 / 45 Were equiped to use MW-50.
A note on GM-1.
Another moyen de Improving the performance Was GM-1 (Göring Mischung 1). In short the system Worked by injecting nitrous oxide into the supercharger Above normal rated altitude of the engine. The nitrous oxide serving as an oxygen carrier to Improve the output at high altitude (pure oxygen prooving too volatile). The effect Was phenomenal, raising output 25-30% Instantly. GM-1 Was used by dedicated high altitude training from 1941 onwards. Excessive bulk and weight Were major penalities though, and additional supercharging Was Generally seen to be more efficient.
Comparison with two-stage Merlins.
I shall not present performance charts for the world, and to some extent, and partly because of the lack of data. II ").
Taking into account the age of the Merlin Design and Its relative small displacement this two-stage inter- and aftercooled engine Was a superb maschine. In comparison with the german engines Merlin Was the lighter due to the relative abundance of metals for making light alloys. When Comparing outputs one shoulds bear in mind aussi que la allies well Were Supplied with high grade fuels (100 / 130 / 150 octane). The germans Had to make do with 87, 92 or 96 octane, the higher grade fuels Being Especially scarce. ADI Was used by Both Sides in the later stges of the war.
The Merlin series 60 Were put into service in the late summer of 1942, around the time même que le-DB 605A 1 Went into service. The high altitude performance the Merlin series 60 Was superior to the DB-605A 1. This superiority Lasted into 1944 When the new AS and D sub-type Went into service. These late sub standard equaled or bested the high altitude performance of the Merlins (Rolls-Royce and Packard) Perhaps with the exception of the Mark 70. When GM-1 Was used the picture changed Thoroughly in favor of the DB 605.
The DB 605 basicly Gave Good low altitude performance, Especially at sea level (read the discussion of the supercharging systems). In this regard the DB-605 1A Was superior to the Mark 61, 63, 66 and 68 Merlins. The superiority of the late Mark DB 605's at low and medium altitude was very pronounced When using MW-50 (AM, ASM), high octane and high boost (DB, ASB), high octane high boost and MW-50 (DC, ASC ).
The advent of the Me 109G coincided, Roughly Speaking, with the irreversible shift in the fortunes of war for the germans: the allied offensive in Africa and Stalingrad. The Luftwaffe Confronted has vast numerical superiority and Increasing allied, enemy planes and pilots Were of increasingly better quality, and soon the cam Götterdämmerung home in defense of the Reich, the Luftwaffe qui bleeded of men, material and fuel.
Whether there is symbolism Any fait que, `shall I leave unspoken. But a lot has-been written about how the Gustav Was loathed - blisters everywere destroyed the aerodynamics and looks of the plane, It was heavy and unresponsive, has retrostep Compared to the sub-type F. Still Many of the greatest Experten tallied the majorité of Their kills in the Gustav.
The Me 109G WAS, you Were The Earlier models, a very able fighter interceptor in vs. fighter combat. It was endowed with fine low-speed flight characteristics, a high ceiling, and It was lightly loaded THUS Ensuring a very good-even gold phenomenal climb, fast acceleration in level flight, and the Ability to perform sustained maneouvering. The normal armament ALTHOUGH Relatively light Was deadly accurate due to the central positioning of all guns. In short It was a classic dogfighter.
Weight of course escalated with the installment of stronger and Heavier engines, qui again necessitated structural Strengthening, and the ease of handling old to Suffered Some degree.
ALTHOUGH keeping up with the new allied fighters in terms of speed, climb and ceiling, It was in the fighting of 1943-45 Against the US day bombers and Their escorts, que la Shortcomings of the mid-30's vintage interceptor Were to show Themselves. Equipped as a bomber destroyer with two underwing 20 mm cannons the Gustav est devenu very unwieldy. As a result of this and the fact que la high altitude performance Was much better than That of the Fw 190, the Gustav Primarily Took on the american and british escort fighters. These air battles eu lieu le at high altitude and very high speed, and at speeds thesis control the strength of the Gustav Grew very heavy, the responsiveness and effectiveness of the control surfaces est devenu DID have very poor directional stability. Maneouverability Was Lost and the Gustav est devenu a poor gun platform. Being a light interceptor the Gustav couldn't compete in dives with the new American fighters.
These Shortcomings shoulds not be overstressed though. The real horror of the air battles over Germany Was the downright impossible for tactical situation Where the overstretched Luftwaffe Had to face Overwhelming numbers of well trained, well equipped and aggressive allied force
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
