Water injection in Formula Renault 1
Share this article with your friends:
Tags: Rally, Formula 1, competition, injector, water, performance, power, Ferrari, Renault, octane, detonation, Turbo
Introduction
The injection of water on very high performance engines used in competition has been a common custom in 70 years 80.
The purpose of these water injections had at least 3 distinct essential roles:
- increase the admission rate, Ie the mixing mass, cooling the mixture or intake air by evaporation of the water. So this was increasing the specific power of the engine.
- increase resistance to detonation of the mixture (Ie increase the octane number of the mixture). In this sense, it joined the MW50 injection - Methanol Water - on the 2ieme World War fighter aircraft.
- cool internal components (Including: folder, valve seat, piston ...) engine during heavy duty.
These water injection processes have all been banned rally type of official competition or in Formula 1 As to limit the race for power. These processes are however still used in some competitions dragster or tractor pulling ...
Let us now see some concrete examples of water injection in competition: Renault Sport Formula 1, Ferrari, and SAAB.
Renault Sport logo F1
Philippe Chasselut, responsible for "piston heads" in the research team and Renault Sport development remembers those days:
In 1982 the Renault Turbo V6 developed 585 horses, it was the first engine used in F1. In 1977, 525 it was horses, gain power between these versions 2 was minimal. But during the years we focused on other field: reliability, smoothing of the power curve and decrease response time (power to command). Once these atteinds goals, we sought to increase power and, in 1986, 6 was Turbo V870 the horses in race conditions. So if between 1977 and 1982, 60 we won hp (11,5%), we had gained almost 300 (51,3%) between 1982 and 1986.
Formula 1 30 1982 RE
In theory, all he had to do to increase the power of a turbocharged engine was to increase the boost pressure. Nevertheless, engine components must be able to withstand this extra power (so internal efforts). That was our main concern when we started up the power 1982. The first obstacle was the detonation, this phenomenon appears when you admit a large amount of mixture in the cylinders and causes abnormal combustion (not controlled). Road vehicles the detonation, also known as knock name, does not cause damage to the engine. But in Formula 1, the detonation forces are so great that the piston can be drilled, and passing the combustion gases into the crankcase ...
View of V6
View of V6 of 1982
To reduce capacity in the detonation of an engine, we first had thought to find a way to cool the air mixture, which had been compressed and therefore heated by the Turbo. This was therefore the function of heat exchangers (intercooler). However, their effectiveness was limited when the ambient outside temperature was very high (of Brazil GP) or during large price carried out at high altitude (South Africa, Mexico ...).
Under these conditions, or oxygen was rarefied by the altitude is the mass of air passing through the intercooler was decreased by the ambient temperature and therefore the expected cooling effect was less.
In 1982, Jean Pierre Boudy who had the idea of ​​lowering the temperature of the air leaving the Turbo by injecting water into the intake. Once the water was in contact with hot air, it is thus sprayed and pumped heat to this air. The temperature of the intake mixture (gas and air) then decreased during its passage through the intake manifold. So we managed to decrease to 10 12 ° C the temperature of the compressed air inlet that was before around 60 ° C. It was enough to prevent the detonation!
A water tank Litres 12 ...
Cockpit
Cockpit
During the ordeal opening 1983 season, the Brazilian Grand Prix, Renault became the first manufacturer to use an injection to Formula 1 to decrease the temperature of the intake mixture.
The system included a tank 12 liters of water, set on one of the side of the car and a control unit installed behind the pilot's head. This control unit included an electric pump, a pressure regulator and a pressure sensor. This sensor triggered the system once the intake boost pressure exceeded 2,5 bars. Below this pressure, there was no risk of detonation so the water injection was not helpful. The water was drawn in by the pump and passed through the regulator which maintained a constant flow before being injected into the collector.
This system required to start each race with overweight 12 L. This handicap weight lost us 3 tenths per lap in the practice sessions. But it was a lesser problem than the "classic" method of road vehicles which was to delay the spark advance. Renault was therefore the first manufacturer to adopt water injection to maintain the turbo-detonation engines (which was destructive to engines).
Once the detonation problem solved, Renault could focus on increasing the power ...
Results?
It is 1977 the 'Régie' launches in F1. the time of the settlement offers two possibilities to motorists: a liter atmo 3 or 1,5 liter turbo. While all the teams are opting for large three-liter turbo Renault made the bet with a small V6.
At Silverstone, the 17 July RS01 Renault made its first laps. Weakness of the turbo engine, reliability is sorely lacking during the first races to the point that the RS01 is nicknamed the yellow teapot because of its engines breaks into a cloud of smoke. But gradually, the Renault technology becomes more successful. In 1978 Renault turbo imposes the 24 Hours of Le Mans and in 1979, this is the first victory in the Diamond F1 at the Grand Prix of France.
From these early successes, all the teams will follow in the Renault turbo technology to become indispensable from 1983. In the early 90 years, Renault has won for six years the world title as engine manufacturer.
Renault RS01 always moving.
Cockpit
Formula Renault 1 RS01
Renault RS01:
Engine: 6 cylinder V center position, turbocharger, 1 492 cm3, 525 10 500 hp r / min, maximum speed approx. 300 km / h
Transmission: rear wheel - 6 box speed +
Brakes: ventilated discs on all four wheels
Dimensions: length. 4,50 m - width. M 2,00 - 600 kg weight
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
