oil rise: doped tractors on national FR3
The rise in oil is not all bad! Today a report presented a tractor modified according to the Pantone process (water doping) in the Lille region.
If you don't know what water doping is, read this page.
To my knowledge, this is the first nationally broadcast report about tractor water doping. Too bad that the interviewee appropriates the performance of the system a little while, as I specify on this page, it is Mrs David and the farmer of Tractor 22 who are the “inventors”… and this in the year 2000!
Let's not forget the site Quanthomme which disseminated all this work and it remains the reference in this field. This is also why you will not find many detailed plans or testimonials on the econology site (except in the .pdf and patent reports). Our goal is first of all to understand the system before applying it. (Even if one cannot be done without the other)
Read also:  Recycling photo report in Belgium
This report is a good thing and if a visitor could record the rebroadcast tonight between 19 and 20h, we could consider putting it on the site.
In the meantime you can view the 12/14 edition on this page, click here.
Leave comments
Your email address will not be published. Required fields are marked with *
