US20110209569A1 - Power multiplier lever system - Google Patents
Power multiplier lever system Download PDFInfo
- Publication number
- US20110209569A1 US20110209569A1 US12/854,162 US85416210A US2011209569A1 US 20110209569 A1 US20110209569 A1 US 20110209569A1 US 85416210 A US85416210 A US 85416210A US 2011209569 A1 US2011209569 A1 US 2011209569A1
- Authority
- US
- United States
- Prior art keywords
- power
- lever
- lever system
- wheels
- power multiplier
- Prior art date
- Legal status (The legal status is an assumption and is not a legal conclusion. Google has not performed a legal analysis and makes no representation as to the accuracy of the status listed.)
- Abandoned
Links
Images
Classifications
- F—MECHANICAL ENGINEERING; LIGHTING; HEATING; WEAPONS; BLASTING
- F04—POSITIVE - DISPLACEMENT MACHINES FOR LIQUIDS; PUMPS FOR LIQUIDS OR ELASTIC FLUIDS
- F04B—POSITIVE-DISPLACEMENT MACHINES FOR LIQUIDS; PUMPS
- F04B9/00—Piston machines or pumps characterised by the driving or driven means to or from their working members
- F04B9/02—Piston machines or pumps characterised by the driving or driven means to or from their working members the means being mechanical
- F16—ENGINEERING ELEMENTS AND UNITS; GENERAL MEASURES FOR PRODUCING AND MAINTAINING EFFECTIVE FUNCTIONING OF MACHINES OR INSTALLATIONS; THERMAL INSULATION IN GENERAL
- F16H—GEARING
- F16H21/00—Gearings comprising primarily only links or levers, with or without slides
- F16H21/10—Gearings comprising primarily only links or levers, with or without slides all movement being in, or parallel to, a single plane
- F16H21/16—Gearings comprising primarily only links or levers, with or without slides all movement being in, or parallel to, a single plane for interconverting rotary motion and reciprocating motion
- F16H21/18—Crank gearings; Eccentric gearings
- F16H21/22—Crank gearings; Eccentric gearings with one connecting-rod and one guided slide to each crank or eccentric
- F16H21/32—Crank gearings; Eccentric gearings with one connecting-rod and one guided slide to each crank or eccentric with additional members comprising only pivoted links or arms
- F03—MACHINES OR ENGINES FOR LIQUIDS; WIND, SPRING, OR WEIGHT MOTORS; PRODUCING MECHANICAL POWER OR A REACTIVE PROPULSIVE THRUST, NOT OTHERWISE PROVIDED FOR
- F03G—SPRING, WEIGHT, INERTIA OR LIKE MOTORS; MECHANICAL-POWER PRODUCING DEVICES OR MECHANISMS, NOT OTHERWISE PROVIDED FOR OR USING ENERGY SOURCES NOT OTHERWISE PROVIDED FOR
- F03G7/00—Mechanical-power-producing mechanisms, not otherwise provided for or using energy sources not otherwise provided for
- F03G7/10—Alleged perpetua mobilia
- F04B35/00—Piston pumps specially adapted for elastic fluids and characterised by the driving means to their working members, or by combination with, or adaptation to, specific driving engines or motors, not otherwise provided for
- F04B35/01—Piston pumps specially adapted for elastic fluids and characterised by the driving means to their working members, or by combination with, or adaptation to, specific driving engines or motors, not otherwise provided for the means being mechanical
- F04B53/00—Component parts, details or accessories not provided for in, or of interest apart from, groups F04B1/00 - F04B23/00 or F04B39/00 - F04B47/00
- F04B53/14—Pistons, piston-rods or piston-rod connections
- F16H—GEARING
- Y—GENERAL TAGGING OF NEW TECHNOLOGICAL DEVELOPMENTS; GENERAL TAGGING OF CROSS-SECTIONAL TECHNOLOGIES SPANNING OVER SEVERAL SECTIONS OF THE IPC; TECHNICAL SUBJECTS COVERED BY FORMER USPC CROSS-REFERENCE ART COLLECTIONS [XRACs] AND DIGESTS
- Y10—TECHNICAL SUBJECTS COVERED BY FORMER USPC
- Y10T—TECHNICAL SUBJECTS COVERED BY FORMER US CLASSIFICATION
- Y10T74/00—Machine element or mechanism
- Y10T74/18—Mechanical movements
- Y10T74/18056—Rotary to or from reciprocating or oscillating
Definitions
- This disclosure relates to a power multiplier lever system that gives an increase in mechanical power generated by the motor thereby giving greater piston movement.
- compressed air is an input used in industry a lot and it is possible to see its use in many varied industrial fields, such as, for example, in the production processes of plastic parts, in pneumatic conveying, in industrial machine controls among other uses.
- Air compressors are the equipment with which we turn this fluid into a power source of summary importance. We have already pointed out above the facilities and benefits for industry that air compressor use has brought to industrial development.
- Air compressors are equipment that raises air pressure using mechanical means usually driven by electric motors or internal combustion engines. During this process power used is lost making the total useful work very small in comparison with the power spent. Therefore, in reality it is the power loss that is the main problem that impedes a greater and better air compressor use.
- JP 1,0238,474 shows an air compressor that uses a high and low pressure discharge tank system in such a way that the power used is saved during the process.
- an objective of this disclosure is to supply a power multiplier lever system that gives an increase in mechanical power generated by the motor thereby giving greater power to the piston giving a greater compression capacity that makes air compression possible without the need to use a large quantity of mechanical power.
- the power multiplier lever system is made of wheels and levers positioned at distinct angles which operate as a multiplier making the use of a high powered motor unnecessary, in other words, it is unnecessary to produce a large quantity of mechanical power.
- FIG. 1 is a front view of the first power multiplier lever system combination where we can see the first lever pair positioned at 90° in relation to the floor;
- FIG. 2 is a front view of the first power multiplier lever system combination where we can see the first lever pair has started its movement in function of the axle rotation which induces movement in the wheel to which the first lever pair is coupled;
- FIG. 3 is front views of the first power multiplier lever system combination where we can see the first lever pair continues moving;
- FIG. 4 is a perspective view of first power multiplier lever system combination where we can see the lever pairs
- FIG. 5 is a front view of the a second power multiplier lever system combination where we can see the first lever pair is positioned at 90° in relation to the floor;
- FIG. 6 is a front view of the a second power multiplier lever system combination where we can see the first lever pair has started its movement in function of the axle rotation which induces movement in the wheel to which the first lever pair is coupled;
- FIG. 7 is a front view of the a second power multiplier lever system combination where we can see the first lever pair continues moving;
- FIG. 8 is a front view of the a third power multiplier lever system combination where we can see the first lever pair is positioned at 0° in relation to the floor;
- FIG. 9 is a front view of the a third power multiplier lever system combination where we can see the first lever pair has started its movement in function of the axle rotation which induces movement in the wheel to which the first lever pair is coupled;
- FIG. 10 is a front view of a third power multiplier lever system combination where we can see the first lever pair continues moving.
- the wheels and levers are positioned at distinct angles which operate as a power multiplier when activated.
- the axle power/torque is multiplied from the power generating source due to the angles made by the levers position.
- Two wheels are connected directly to the motor axle and are also connected to the first levers. The last pair of levers is connected to the pistons.
- the power multiplier lever system can have the selected combination of a system consist of 7 lever pairs where the first is connected to the wheels that are directly coupled to the motor axle. The first pair of levers is connected to the wheels in opposite positions.
- the power multiplier lever system can have the selected combination of a system consist of 6 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- the power multiplier lever system can have the selected combination of a system consist of 8 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- the power multiplier lever system can have the selected combination of a system comprises 7 lever pairs where the first is connected to the wheels that are directly coupled to the motor axle.
- the power multiplier lever system can have the selected combination of a system comprises 6 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- the power multiplier lever system can have the selected combination of a system comprises 8 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- the power multiplier lever system causes the axle power/torque to be multiplied from the power generating source due to the angles made by the levers position. These angles the consequence of the position of the levers are defined in function of the objective for which it will be used.
- the power is received by the piston is greater than the power that left the motor axle directly because of the angles used and the calculations made beforehand for the power multiplier lever system.
- the first selected combination there is a lever system with 7 lever pairs where the first pair is connected to the wheels that are coupled directly to the motor axle.
- This first lever pair is connected to wheels in opposite positions, in other words, when the wheels are stationary in their starting position one lever of the pair is positioned at a point of this wheel and the other lever of the same pair is positioned at exactly 180° from this point.
- a lever system with 6 lever pairs where the first pair is connected to the wheels that are coupled directly to the motor axle.
Abstract
A power multiplier lever system gives an increase in mechanical power generated by the motor thereby giving greater power to the piston giving a greater compression capacity that makes air compression possible without the need to use a large quantity of mechanical power.
Description
- This application claims the benefit of and priority to U.S. Provisional Application Ser. No. 61/239,034, filed Sep. 1, 2009, the contents of which are incorporated by reference herein in its entirety.
- Industrial development was always followed by improvements in energy source use. Automation of industrial processes required and continues to require a great use of energy and there are countless ways in which these can manifest in accordance with the objective to be achieved. Electrical power the most traditional of the forms mentioned, next hydraulic characterized by its use when great forces are used and finally compressed air which has many uses.
- Therefore compressed air is an input used in industry a lot and it is possible to see its use in many varied industrial fields, such as, for example, in the production processes of plastic parts, in pneumatic conveying, in industrial machine controls among other uses.
- Therefore the importance that such energy acquired in industrial and technological development is unquestionable. The high efficiency level of compressed air use, the ease in which it is conducted and the non generation of harmful waste make this input one of the new power resources of the industrial age.
- Moreover, air is easily found in nature. However, to compress it is necessary to use compressors and from then on, the use of this power source shows its few but relevant negative points.
- However, to compress air in the cylinder it is necessary to use a high powered motor which in some situations makes the use of this type of compression unsuitable because of the motor and/or compressor sizes that should be used. Moreover, the power loss that occurs during its production means that air compressor use in industry is still limited and industries choose other compressor types with other compressible fluids, such as oil for example.
- Just as, there many disclosure patents which create in some way means to compensate or avoid power loss in the compression process. The American patent U.S. Pat. No. 6,419,454, for example, deals with a method to control a system consisting of multiple compressors driven by electric motors which by synchronizing the compressor drives loses less power.
- Also the Japanese patent, JP 1,0238,474 shows an air compressor that uses a high and low pressure discharge tank system in such a way that the power used is saved during the process.
- Moreover, several Brazilian patents deal with power multiplication systems, such as for example: PI 9502446-8, that deals with a motor power multiplier using crankshafts, pulleys and steel cables or chains and PI 0702406-1, that deals with a lever power multiplier giving power savings and less final cost to the consumer, this multiplier works with a lever arm, pulleys and ratchets. The two processes above, because they use pulleys, have a lot of friction on the pulley axle that causes a significant resistance source thereby losing its objective of multiplying power/energy.
- Other processes, in order to solve this problem use articulations and levers: PI 0201322-3, that deals with a power multiplier using an axle with a center deviation connected to a piston and levers through articulations, PI 8302216-3, that proposes a sequential power with a continuous or intermittent working capacity which can operate in both low or high rotation and PI 8702053-0, that deals with a leverage motor in which the power is a function of the leverage degree of every lever, the lever quantity and lever linkage quantity. However, these three processes have a leverage system after the pistons and so the power increase generated does not give any benefit regarding the power necessary for piston movement.
- The disclosures in these prior patents are incorporated by reference herein in their entirety.
- Therefore, an objective of this disclosure is to supply a power multiplier lever system that gives an increase in mechanical power generated by the motor thereby giving greater power to the piston giving a greater compression capacity that makes air compression possible without the need to use a large quantity of mechanical power.
- To achieve the objective above the power multiplier lever system is made of wheels and levers positioned at distinct angles which operate as a multiplier making the use of a high powered motor unnecessary, in other words, it is unnecessary to produce a large quantity of mechanical power.
FIG. 1 is a front view of the first power multiplier lever system combination where we can see the first lever pair positioned at 90° in relation to the floor; -
FIG. 2 is a front view of the first power multiplier lever system combination where we can see the first lever pair has started its movement in function of the axle rotation which induces movement in the wheel to which the first lever pair is coupled; -
FIG. 3 is front views of the first power multiplier lever system combination where we can see the first lever pair continues moving; -
FIG. 4 is a perspective view of first power multiplier lever system combination where we can see the lever pairs; -
FIG. 5 is a front view of the a second power multiplier lever system combination where we can see the first lever pair is positioned at 90° in relation to the floor; -
FIG. 6 is a front view of the a second power multiplier lever system combination where we can see the first lever pair has started its movement in function of the axle rotation which induces movement in the wheel to which the first lever pair is coupled; -
FIG. 7 is a front view of the a second power multiplier lever system combination where we can see the first lever pair continues moving; -
FIG. 8 is a front view of the a third power multiplier lever system combination where we can see the first lever pair is positioned at 0° in relation to the floor; -
FIG. 9 is a front view of the a third power multiplier lever system combination where we can see the first lever pair has started its movement in function of the axle rotation which induces movement in the wheel to which the first lever pair is coupled; -
FIG. 10 is a front view of a third power multiplier lever system combination where we can see the first lever pair continues moving. - A power multiplier lever system having a power multiplier lever system that provides an increase of mechanical power generated by the motor, thereby giving greater power to the piston, which makes air compression possible without needing to use a large quantity of mechanical power, comprised by levers, wheels, connectors and pistons. The wheels and levers are positioned at distinct angles which operate as a power multiplier when activated. The axle power/torque is multiplied from the power generating source due to the angles made by the levers position. Two wheels are connected directly to the motor axle and are also connected to the first levers. The last pair of levers is connected to the pistons.
- The power multiplier lever system can have the selected combination of a system consist of 7 lever pairs where the first is connected to the wheels that are directly coupled to the motor axle. The first pair of levers is connected to the wheels in opposite positions.
- The power multiplier lever system can have the selected combination of a system consist of 6 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- The power multiplier lever system can have the selected combination of a system consist of 8 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- The power multiplier lever system can have the selected combination of a system comprises 7 lever pairs where the first is connected to the wheels that are directly coupled to the motor axle.
- The power multiplier lever system can have the selected combination of a system comprises 6 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- The power multiplier lever system can have the selected combination of a system comprises 8 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
- The power multiplier lever system causes the axle power/torque to be multiplied from the power generating source due to the angles made by the levers position. These angles the consequence of the position of the levers are defined in function of the objective for which it will be used.
- Two wheels are directly connected to the motor axle; these wheels are connected to the first levers. Afterwards we have a sequence of lever pairs which will depend on our final objective. The last lever pair will be connected to the pistons.
- The power is received by the piston is greater than the power that left the motor axle directly because of the angles used and the calculations made beforehand for the power multiplier lever system.
- In the first selected combination (it can be seen in
FIGS. 1 to 4 ), there is a lever system with 7 lever pairs where the first pair is connected to the wheels that are coupled directly to the motor axle. This first lever pair is connected to wheels in opposite positions, in other words, when the wheels are stationary in their starting position one lever of the pair is positioned at a point of this wheel and the other lever of the same pair is positioned at exactly 180° from this point. - At the opposite end of the one fixed to the wheel we fix another lever and so on and the last lever pair will couple to the pistons.
- In a second selected combination (it can be seen in
FIGS. 5 to 7 ), there is a lever system with 6 lever pairs where the first pair is connected to the wheels that are coupled directly to the motor axle. This first lever pair is connected to wheels in opposite positions, in other words, when the wheels are stationary in their starting position one lever of the pair is positioned at a point of this wheel and the other lever of the same pair is positioned at exactly 180° from this point. - At the opposite end of the one fixed to the wheel we fix another lever and so on and the last lever pair will couple to the pistons.
- In a third selected combination (it can be seen in
FIGS. 8 to 10 ), we have a lever system with 6 lever pairs where the first pair is connected to the wheels that are coupled directly to the motor axle. This first lever pair is connected to wheels in opposite positions, in other words, when the wheels are stationary in their starting position one lever of the pair is positioned at a point of this wheel and the other lever of the same pair is positioned at exactly 180° from this point. - At the opposite end of the one fixed to the wheel we fix another lever and so on and the last lever pair will couple to the pistons.
- Therefore this disclosure resolves a problem that has impeded the greater use of air compressors in industry, the high relative cost of power use.
- It should be evident to technical experts that this disclosure can be configured in many other specific forms without leaving the spirit or scope of the disclosure. In particular, it should be understood that the disclosure can be configured in the described forms.
- Therefore the examples and configurations presented should be considered illustrative and not restrictive and the disclosure should not be limited to the details supplied in this document, but can be modified inside the scope and equivalence of the attached claims.
Claims (13)
1. A power multiplier lever system having a power multiplier lever system that provides an increase of mechanical power generated by the motor, thereby giving greater power to the piston, which makes air compression possible without needing to use a large quantity of mechanical power, comprised by levers, wheels, connectors and pistons.
2. A power multiplier lever system in accordance with claim 1 , wherein the wheels and levers are positioned at distinct angles which operate as a power multiplier when activated.
3. A power multiplier lever system in accordance with claim 1 wherein the axle power/torque being multiplied from the power generating source due to the angles made by the levers position.
4. A power multiplier lever system in accordance with claim 1 wherein the two wheels that are connected directly to the motor axle and are also connected to the first levers.
5. A power multiplier lever system in accordance with claim 1 wherein the last pair of levers is connected to the pistons.
6. A power multiplier lever system as claimed in any one of the above claims wherein the selected combination of a system consists of 7 lever pairs where the first is connected to the wheels that are directly coupled to the motor axle.
7. A power multiplier lever system in accordance with claim 6 , wherein the first pair of levers is connected to the wheels in opposite positions.
8. A power multiplier lever system as claimed in any one of the above claims comprising a second selected combination of a lever system consisting of 6 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
9. A power multiplier lever system as claimed in any one of the above claims comprising a third selected combination of a lever system consisting of 8 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
10. A power multiplier lever system as claimed in any one of the above claims wherein the selected combination of a system comprises 7 lever pairs where the first is connected to the wheels that are directly coupled to the motor axle.
11. A power multiplier lever system in accordance with claim 10 , wherein the first pair of levers is connected to the wheels in opposite positions.
12. A power multiplier lever system as claimed in any one of the above claims wherein a second selected combination of a lever system comprises 6 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
13. A power multiplier lever system as claimed in any one of the above claims wherein a third selected combination of a lever system comprises 8 lever pairs, where the first pair is connected to the wheels that are coupled directly to the motor axle.
Priority Applications (10)
Application Number | Priority Date | Filing Date | Title |
US12/854,162 US20110209569A1 (en) | 2009-09-01 | 2010-08-10 | Power multiplier lever system |
KR1020127007296A KR20120061907A (en) | 2009-09-01 | 2010-08-31 | Power multiplier system with levers |
MX2012002607A MX2012002607A (en) | 2009-09-01 | 2010-08-31 | Power multiplier system with levers. |
EP10813412.3A EP2474738A4 (en) | 2009-09-01 | 2010-08-31 | Power multiplier system with levers |
PCT/IB2010/053909 WO2011027294A2 (en) | 2009-09-01 | 2010-08-31 | Power multiplier system with levers |
AU2010290876A AU2010290876A1 (en) | 2009-09-01 | 2010-08-31 | Power multiplier system with levers |
JP2012527434A JP2013504021A (en) | 2009-09-01 | 2010-08-31 | Energy amplification lever system |
CN2010800395063A CN102483048A (en) | 2009-09-01 | 2010-08-31 | Power multiplier system with levers |
BR112012004259A BR112012004259A2 (en) | 2009-09-01 | 2010-08-31 | power multiplier levers system |
CA2771873A CA2771873A1 (en) | 2009-09-01 | 2010-08-31 | Energy multiplier levers system |
Applications Claiming Priority (2)
US23903409P | 2009-09-01 | 2009-09-01 | |
Publications (1)
Publication Number | Publication Date |
US20110209569A1 true US20110209569A1 (en) | 2011-09-01 |
Family
ID=43649719
Family Applications (1)
Application Number | Title | Priority Date | Filing Date |
US12/854,162 Abandoned US20110209569A1 (en) | 2009-09-01 | 2010-08-10 | Power multiplier lever system |
Country Status (10)
Country | Link |
US (1) | US20110209569A1 (en) |
EP (1) | EP2474738A4 (en) |
JP (1) | JP2013504021A (en) |
KR (1) | KR20120061907A (en) |
CN (1) | CN102483048A (en) |
AU (1) | AU2010290876A1 (en) |
BR (1) | BR112012004259A2 (en) |
CA (1) | CA2771873A1 (en) |
MX (1) | MX2012002607A (en) |
WO (1) | WO2011027294A2 (en) |
Families Citing this family (2)
Publication number | Priority date | Publication date | Assignee | Title |
WO2017000077A1 (en) * | 2015-06-29 | 2017-01-05 | Navea Lucar Juan Lester | Force amplifier |
CN108775388B (en) * | 2018-08-29 | 2023-06-16 | 蔡兆昶 | Duplex lever synchronous rotation reinforcement transmission case |
Citations (12)
US4113065A (en) * | 1975-07-08 | 1978-09-12 | Robert Staines | Scissors lift |
US4194723A (en) * | 1978-04-14 | 1980-03-25 | Jlg Industries, Inc. | Scissors linkage workman's platform |
US5295898A (en) * | 1992-12-22 | 1994-03-22 | Acraloc Corporation | Loin puller |
US5901270A (en) * | 1996-09-12 | 1999-05-04 | The Plastic Forming Company, Inc. | Apparatus for hot fluid trimming of plastic molded articles |
US6241057B1 (en) * | 1998-12-03 | 2001-06-05 | Westinghouse Air Brake Company | Hydraulic parking brake lever arrangement for a railroad vehicle braking system |
US6371008B1 (en) * | 1999-03-31 | 2002-04-16 | Sorelec | Water-raising pump |
US6510786B1 (en) * | 1999-04-26 | 2003-01-28 | Mueller Weingarten Ag | Hydromechanical press drive |
US20030164021A1 (en) * | 2000-06-19 | 2003-09-04 | Gordon Charles M. | Panel curving machine |
US20040024385A1 (en) * | 1999-11-12 | 2004-02-05 | Microdexterity Systems, Inc. | Manipulator |
US6809426B2 (en) * | 2003-01-06 | 2004-10-26 | Claude A. Naar | Gravity-based vehicle power system |
US6858950B1 (en) * | 1997-08-22 | 2005-02-22 | Istvan Simon | Liquid power machine |
US6883641B2 (en) * | 2002-08-13 | 2005-04-26 | Romain Julien | Mobile elevator working and load-lifting platform |
Family Cites Families (14)
US4151758A (en) * | 1977-08-01 | 1979-05-01 | Natalie Adam J | Power multiplier |
BR8302216A (en) | 1983-04-29 | 1984-12-04 | Jose Aparecido De Souza | POWER MULTIPLICATOR WITH ROTATION SPEED MAINTENANCE |
DE3640136A1 (en) * | 1986-11-25 | 1988-06-01 | Helmut Juengling | Compression device |
BR8702053A (en) | 1987-04-06 | 1988-11-01 | Osvaldo Dela Coleta | LEVER ENGINE |
JP2605333B2 (en) | 1988-03-17 | 1997-04-30 | 松下電器産業株式会社 | Ultrasonic motor drive |
IT1235432B (en) * | 1988-11-16 | 1992-07-10 | Sarno Cosimo | FOUR-POINT DEAD POINT CRANK |
DE4317226A1 (en) * | 1993-05-24 | 1994-12-01 | Schweizer Viktor Dipl Ing Fh | Con rod-guided engine |
BR9502446A (en) | 1995-08-02 | 1997-08-26 | Marcelo Luiz Sarti | Engine power multiplier |
ITPZ990003A1 (en) * | 1999-07-02 | 2001-01-02 | Cosimo Sarno | ISOMETRIC COMBUSTION SYSTEMS. |
GR1003523B (en) * | 2000-04-21 | 2001-01-22 | Αλεξανδρου Παναγιωτης Γεωργιου | Engines with multipliers |
US6419454B1 (en) | 2000-06-14 | 2002-07-16 | Leo P. Christiansen | Air compressor control sequencer |
BR0201322A (en) | 2002-04-01 | 2003-12-16 | Alexandre Hideki Freita Sonobe | Force multiplier |
DE202004000470U1 (en) * | 2004-01-14 | 2004-05-06 | Schönherr, Sabina | Vehicle's continuously variable transmission has compressor which directs force via piston, connecting rod and adjusting device upon one-sided lever arm rotatably mounted by one side on fixed point |
BRPI0702406A2 (en) * | 2007-07-11 | 2009-02-25 | Montini Consuelo Soares | force multiplier by leverage |
2010
- 2010-08-10 US US12/854,162 patent/US20110209569A1/en not_active Abandoned
- 2010-08-31 MX MX2012002607A patent/MX2012002607A/en not_active Application Discontinuation
- 2010-08-31 BR BR112012004259A patent/BR112012004259A2/en not_active IP Right Cessation
- 2010-08-31 WO PCT/IB2010/053909 patent/WO2011027294A2/en active Application Filing
- 2010-08-31 AU AU2010290876A patent/AU2010290876A1/en not_active Abandoned
- 2010-08-31 JP JP2012527434A patent/JP2013504021A/en active Pending
- 2010-08-31 KR KR1020127007296A patent/KR20120061907A/en not_active Application Discontinuation
- 2010-08-31 EP EP10813412.3A patent/EP2474738A4/en not_active Withdrawn
- 2010-08-31 CN CN2010800395063A patent/CN102483048A/en active Pending
- 2010-08-31 CA CA2771873A patent/CA2771873A1/en not_active Abandoned
Patent Citations (13)
US6702805B1 (en) * | 1999-11-12 | 2004-03-09 | Microdexterity Systems, Inc. | Manipulator |
Also Published As
Publication number | Publication date |
CA2771873A1 (en) | 2011-03-10 |
KR20120061907A (en) | 2012-06-13 |
AU2010290876A1 (en) | 2012-04-26 |
EP2474738A2 (en) | 2012-07-11 |
BR112012004259A2 (en) | 2016-02-16 |
MX2012002607A (en) | 2012-04-02 |
JP2013504021A (en) | 2013-02-04 |
EP2474738A4 (en) | 2013-05-22 |
WO2011027294A3 (en) | 2011-11-10 |
CN102483048A (en) | 2012-05-30 |
WO2011027294A2 (en) | 2011-03-10 |
Similar Documents
Publication | Publication Date | Title |
US20170067454A1 (en) | Compressed air energy storage system | |
CN202176687U (en) | Multi-stage linkage driving telescopic push rod device | |
US20110209569A1 (en) | Power multiplier lever system | |
CN108248089A (en) | A kind of control method of double execution unit hydraulic presses | |
CN2775362Y (en) | Energy storage type fluid pressure forming device | |
CN103527117A (en) | 360-degree continuous rotation large-torque screwing and buckling machine | |
CN201494971U (en) | Hydraulic type mechanical expansion and contraction shaft | |
CN202646434U (en) | Power transmission coupler capable of realizing rapid meshing | |
CN204209476U (en) | A kind of steel rider reparation fixing tool | |
CN203685512U (en) | Water pump | |
CN102840118A (en) | Dual-pressure compressor | |
CN209138889U (en) | Piston push centrifuge power mechanism | |
CN209800429U (en) | Cam plunger type hydraulic high-frequency high-voltage pulse impact test device | |
CN204113553U (en) | A kind of rise-fall type generator set | |
CN204099336U (en) | Electro-hydraulic servo power cylinder | |
CN202510313U (en) | Dual-drive air compressor device | |
Korucu et al. | Design and Experimental Investigation of Pneumatic Movement Mechanism Supported by Mechanic Cam and Crank Shaft. | |
CN204553406U (en) | A kind of high speed hydraulic cylinder and shredmaster | |
CN2623366Y (en) | Driving force device of card punchs | |
CN220270929U (en) | Integrated gas supercharging sampling device | |
CN205101496U (en) | Power transmission device | |
CN201744544U (en) | Novel small-sized manual and motor-driven punch press | |
CN102528510A (en) | Center processor broaching tool drive hydraulic cylinder oil supply mechanism | |
CN107514412A (en) | A kind of energy-saving hydraulic system power source and work system for batch (-type) acting | |
WO2016200912A1 (en) | Pressure controlled hydraulic engine |
Legal Events
Date | Code | Title | Description |
STCB | Information on status: application discontinuation |
Free format text: ABANDONED -- FAILURE TO RESPOND TO AN OFFICE ACTION |
