convincing test an electric generation system from the force of the waves
Share this article with your friends:
Scientists from the Academy of Sciences of China's Energy Conversion Institute in Guangzhou have been able to stably generate electrical energy from the strength of the waves during the sea trial of their new system.
Les resultats experimentaux du systeme se sont reveles satisfaisants en terme de stabilite et de performance dans le cas de petites vagues.Les vagues sont une source d’energie peu exploitee car tres instable. Des statistiques ont revele que l’energie maximale qui peut etre generee est 7 a 10 fois superieure a la moyenne d’energie obtenue en dix minutes. L’essai du nouveau systeme a permis de produire 6 kW et a montre une bonne stabilite.
The Institute plans to build the first wave power station. It will produce electricity for the consumption of a village and also for the desalination of water.
Sources: Academy of Sciences of China,
http://english.cas.ac.cn/Eng2003/news/detailnewsb.asp?infoNo=25327 ;
Energy Conversion Institute in Canton,
http://www.giec.ac.cn/giec/giec_english/index.htm
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
