Download: GlassX, ultra high thermal performance glazing
A transparent thermal coating ultra high performance: the Crystal GlassX
GLASSXcrystal integrates 4 elements of the system in a single functional unit: Transparent thermal insulation - protection against excessive heat - transformation of energy - thermal collector.
A triple insulating glass structure offers excellent thermal insulation with a U value of less than 0,48 U = W / m2K.
A prismatic glass placed in the space between the panes reflects the summer sun outwards when it is at its highest, with angles of incidence greater than 40 °. On the other hand, the winter sun crosses the sun protection at its full intensity.
The central element of GLASSXcrystal is a thermal storage module which absorbs solar energy and releases it with a time lag in pleasant radiant heat. PCM (Phase Change Material) in the form of a salt hydrate is used as accumulator material. The heat build-up occurs through the melting of PCM; for cooling, the accumulated heat is released again. The salt hydrate is sealed in polycarbonate containers.
Read also:  Make popcorn with 3 4 or cell phones?
Inside the premises, the element is closed by a safety glass with a single 6 mm pane, the arrangement of which can be changed.
More: energy storage by phase change and example of GlassX Crystal
Download file (a newsletter subscription may be required): GlassX, ultra high thermal performance glazing
Leave comments
Your email address will not be published. Required fields are marked with *
