Petroleum fuels: petrol, diesel, LPG kerosene and their additives
Characteristics of common petroleum fuels: petrol, diesel, kerosene, LPG, CNG, Butane, Propane and the main petroleum additives
Keep in mind that no fuel is a pure compound. They are all (with some exceptions) a mixture of miscible compounds with complementary properties. Characteristics definitions are on fuel definitions
Gasoline (heptane)
Chemical formula:
C7 H16 (approached to 4 7 carbon atoms)
Octane number:
RON 95 / 98
distillation characteristics:
Range of around 30 to 210 ° C
Starting point 27 ° C
Evaporating temperature:
between room temperature and 215 ° C
Density:
0,755 (approached to 0,72 0,78 15 to ° C)
Flash point:
-40 ° C
Calorific power:
10 500 / 11 300 kcal / kg
7 600 / 8 200 kcal / liter
44 000 kJ / kg
Boiling temperature:
-30 To 190 ° C
Auto-ignition temperature:
300°
Steam pressure:
45-90 ° C to 37,8kPa
Vapor density:
3 4 to (air = 1)
Viscosity:
0,5 to 0,75mm² / s 20 ° C
Diesel oil (cetane): diesel, diesel, diesel or fuel oil
Chemical formula:
C21 H44 (approached to 12 22 carbon atoms)
Cetane Number:
initial point> = 150 ° C
distillation range 150 to 380 ° C
between 180 and 370 ° °
Density:
0,845 (approached to 082 1,85 15 to ° C)
Flash point:
55°C
calorific power:
43 000 kJ / kg
Cold resistance:
- 5 ° C the diesel becomes cloudy
- 15 ° C limit of filterability
- 18 ° C pour point
These are the paraffins contained in the diesel that turn into crystals when the temperature drops
Mass suffering:
- Before October 1, 1996 it was at 2%
- Since October 1, 1996 it is less than 0,05%
- -180 to 360 ° C
250°
Steam pressure:
Vapor Density:
> 5 (air = 1)
Viscosity:
<7mm² / s at 40 ° C
Kerosene (also called "kerosene")
Density:
0,77 to 0,83
Calorific power:
43 105 kJ / kg
Chemical formula:
C10 of H22 to C14 H30
Cold resistance:
-50 ° C
LPG OR LPG (Liquefied Petroleum Gas)
Octane number:
RON 110
Composed of 50% butane and 50% propane (the proportions change according to the seasons 60 to 40 in summer)
Chemical formula:
C3H 8, C4H10
Density:
2,3555 (approached to 0,51 0,58 15 to C [liquid])
Flash point:
<-50 ° C
> 400 ° C
Steam pressure:
4 15 bars ° C
Steam pressure:
= <1550kPa at 40 ° C
Density:
> = 530kg / m3 at 15 ° C
Evaporation rate:
1 the atmospheric pressure in liquid generates steam around the 255
Calorific power:
11 000 / 11 850 kcal / kg
6 050 / 6 480 kcal / liter
Sulfur content:
0.02% maximum
Storage Pressure:
4 5 to bars
olfactory detection additive:
mercaptan
Advantages:
Reduction compared to gasoline or diesel engine:
- 30 to 65% of NOx and HC
- 40 to 75% of CO
- 15% of CO2
No particles
Higher octane number allowing a reduction in consumption on optimized engines (rarely the case)
It is a valued refining or oil extraction “waste”.
CNG (Natural Gas for Vehicles, methane)
Chemical formula:
CH4 (essentially methane, 80% to 97%)
Octane RON:
120
Ignition temperature:
650°C
Aspect:
naturally colorless and odorless (odor it is added by chemical addition)
Disadvantage:
GVN is stored in the gaseous state. It is compressed under a pressure of 200 bars when filling the vehicle tank.
This filling can last from 1 hour to 7 hours depending on the equipment used.
Advantages:
50% less CO and HC, no sulfur or particles.
High octane number allowing an improvement in engine efficiency.
Stocks are higher than those of crude oil.
Butane
Density: 2,703
Calorific power:
45 600 kJ / kg
Chemical formula:
C4H10
Sulfur content:
0.02% maximum
-5 ° C
liquefaction pressure 15 ° C:
1,5 bar
510 ° C
Octane:
95
approximate composition of commercial butane:
N-butane & isobutane *:
94,8%
Propane:
4,2%
butene:
1%
methyl-propane (formerly iso butane)
Propane
Density:
2,008
Calorific power:
46 300 kJ / kg
Chemical formula:
C3H8
Sulfur content:
0.02% maximum
-42 ° C
7,5 bar
Calorific power:
1 kg: 12,78 13,8 kW kW
M1 3: 23,9 25,9 kW kW
490 ° C
Octane:
100
approximate composition of commercial propane
Propane:
94,9%
N butane & isobutane *:
2,39%
Ethene & Ethane:
2%
Propene (C3H6):
0,89%
butene:
0.039%
Petroleum additives
2 main classes of additives for gasoline:
- octane number improvers
- detergents (keeping the intake circuit in a perfect state of cleanliness at all times limits the adjustments that may be caused by soiling)
Tetraethyl lead:
(used to increase the octane rate)
chemical formula:
Pb (C2H5) 4
origin:
additive providing 4 to 5 octane point to gasoline
associated pollutant:
The lead:
(used to increase the octane rate, and because of its properties lubricated the valve stems and protected the seats by its deposits)
- Was abolished on January 1, 2000 due to pollution.
methyl:
used for unleaded gasoline
tert-butyl ether:
More:
- Forum petroleum products and fossil fuels
- Petroleum fuels
- Equation combustion and CO2
- Synthesis download on the main properties of fuels
- conventional petroleum fuels
Read also:  Meeting with an old "water" engine, mystery solved!
Leave comments
Your email address will not be published. Required fields are marked with *
