Here is the basic plan issued by Pantone on the Internet at the end of 1990 years, re-designed by JL Naudin
Keywords: pantone engine plane, modification, small engine
Click to enlarge.
Be careful, this is a “basic” plan without any improvement and you will quickly see its limits (especially when it comes to using a single bubbler and a bubbler for gasoline). This plan is therefore to be tested only on your mower or a small engine.
Moreover we do not certify that:
- the length of the rod.
- the presence and necessity of the magnetic component (North-South running-in)
For a first approach and find the system that plan enough nonetheless.
For more information and tips for improvements, you can read:
- Engineer report on pantone engine
- forums on pantone motor mounts
- Forum on Pantone engine explanations
Hello,
I made an engine according to the plans and I have a problem because I have a breath at the level of the air inlet, of course the engine is running but chaotically without taking the turns well and any intervention on a valve stops immediately operation?
Could someone help me?
With my thanks and sincere greetings.
Patrick chanu
