Storage of pellets and necessary volume of the silo
Share this article with your friends:
Heating with wood pellets: the question to ask before choosing this method of heating?
1) What are the requirements of a good storage of pellets?
a) Close the boiler as we have said. If you do not have adjacent room: nothing prevents building, if possible, an outdoor annex contiguous to your boiler room.
b) Humidity minimized: The pellets are, you know, the dried wood (RH c) air evacuation during filling: a vent.
automatic feed pellet boiler
The 3 types of automatic feeding a boiler Pellets: not auger, suction and bag (manual)
2) What is the required storage volume?
The storage volume must be sufficient for about a year heating and hot water. This obviously because of the price of delivery!
If you replace your boiler, calculation of the mass required per year is simple: energy 2 kg of pellets = oil 1L. (1 kg pellets = almost 5 kWh). So if you consume 2500L of oil, you will 5 tons of pellets.
German and Austrian standards require Pellet density of 1.200 Kg / m3 (yes the pellet flows: it is heavier than water) which is about to 650 750Kg / m3 for bulk pellets.
So let's take 700 kg / m3 equivalent to oil 350L in a volume of 1000 Litre. We need a 3 times more volume than your annual consumption of fuel oil or to an equivalence of oil 2500L a volume of 7,5 m3.
However it is necessary to also provide a "security" volume from 10 to 15% in our case: 9 m3 for 2500 L oil equivalent.
Therefore at final a pellet volume 3,5 times greater than the storage volume of oil equivalent energy and a tonnage 2 times higher than that of oil (or gas m3).
Read more: financial aid and tax credit for pellets?
Previous article: Questions to ask before switching to pellets?
Feedback
Leave a comment
Your email address will not be published. Required fields are marked with *
