Encounter with an old "water" engine, mystery solved!
Continuation and end of the case of the old water engine presented in this document.
Instead of a "water engine", it was actually a water injection engine, thus joining the work on the Pantone engine.
Water promotes (once again) combustion, but this engine cannot run without “conventional” fuel (and fortunately…).
Conclusion of this "case": the difference between scientific reality and the information circulating (often in good faith) can be important ...
Debate on forums: Gaston water engine
Download file (a newsletter subscription may be required): Meeting with an old water engine: mystery solved
Read also:  Download: Nodal analysis and development by vibratory analysis
Leave comments
Your email address will not be published. Required fields are marked with *
