Hello,
can someone tell me why i can't inflate my booster balloon the pump keeps on running the needle of the mano mounted at 4 bars and goes back down immediately. so like last summer I wanted to re-inflate my balloon except that there is no air the air does not enter my compressor remains blocked on 5 or 6 and nothing happens and the balloon remains at 0.
please
booster tank
There is probably water in the bladder.
If so, consider changing it.
To remove the water, remove the valve. It is unscrewed.
Then start the pump. Water should
get out of the bladder. Switch off the pump, put the
valve, open a valve and put the bladder under
pressure (1.5 bars, I believe, it should be indicated on
the ball ) . R
ePut the pump on.
It will last as long as it lasts.
the ball ) . R
ePut the pump on.
Re: booster tank
mamar66 wrote:Hello,
please
Hello Mamar!
Before inflating your balloon you must completely empty the water and the pressure inside, then you put between 60 and 70% of air pressure of the operating pressure of the water, the rubber membrane or urethane must be stuck on your valve and block the entry of compressed air and that is why you cannot add air to it.
It is not normal that you have to inflate your balloon every year, your valve must leak but you can put a better quality valve cap with a tight seal which will limit leaks.
From what you say I do not think the membrane is pierced otherwise by pressing the valve you would bring out the water which does not seem to be the case.
Stepping behind sometimes can strengthen friendship.
Criticism is good if added to some compliments.
Alain
Alain
Hello
thank you for your answer rabbit I thought the bladder was full of water and the air around above whatever but precisely the bladder does not fill the pressure goes up and down immediately I wanted to empty the balloon before inflating it nothing no water and I cannot inflate the air does not enter. if i unscrew the valve the water will come out there ???
please
martine
please
martine
thank you alain
I emptied the balloon besides there was nothing and how I take off the menbrane from the valve with the pressure of the compressor it did nothing.
60 70% air pressure of water operating pressure ??? that is to say
the balloon mano is set to min 2bars1 / 2 I think and maxi 4
Thank you again for your help
martine
martine
Hello everyone
the bladder may be stuck with rust in the balloon
in this case you probably have a turntable that you can dismantle
to remove the bladder from the walls, hoping it is empty!
anyway expect you to have to change the ball
"we do not inherit the land from our ancestors, we borrow it from our children" St Exupéry
- Similar topics
- Replies
- views
- Last message
- 242 Replies
- 40220 views
Last message by Christophe
View the latest post
18/12/23, 12:38A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 31 Replies
- 33735 views
02/01/08, 14:02A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : Google [Bot] and 109 guests
