Search found 66 results
- 28/01/19, 19:34
- Forum : Agriculture: problems and pollution, new technologies and solutions
- Subject : The lazy garden made in northern Elsass
- answers: 104
Re: The lazy garden made in northern Elsass
Thank you for your answer. I was somewhat expecting this response. I know that the half-mast rose I will make a few feet of it because my daughter is a fan of it, afterwards for the others I am lost. I skimmed over the pdf, but it is very very dense and for an amateur like me a little indigestible. As we are a little ...
- 27/01/19, 18:19
- answers: 104
Hello, I haven't had much time to spend the last few months. So here I am back with a question that torments me: it will soon be the period of sowing tomatoes. I have always made my seeds myself but last year there was a miss so no seeds were collected: cry: ...
- 18/07/18, 23:44
- answers: 104
if it is famous beast, that would mean that the sowings carried out from the beginning of July (it is rather approximate) should be raised. I do not know the cycle of these critters, but for beans I have not had any problems for 2-3 weeks, whereas before it was a disaster. So they must ...
- 18/07/18, 21:18
- answers: 104
the last shot, I opened wide enough (it was to wipe off: shock:) and there it starts to rise. I water them every day (with this heat it quickly burns in the sun). it looks a bit thicker to me than the other times. I will follow this closely. In terms of methodology, it gives that ...
- 16/07/18, 14:19
- answers: 104
I think it's possible to put the cover back once the carrot leaves are in place
- 16/07/18, 12:44
- answers: 104
One of the solutions might be to dismiss well before (I do not know how long) hay to try to thwart the problems you are talking about.
Could a band of 30-40cm wide be the case?
- 15/07/18, 21:34
- answers: 104
I wish it was a problem of seed (I change the mark and presto it is settled), but I think you're right.
has anyone ever tried to sow live on the ground and cover very slightly with hay?
- 15/07/18, 15:59
- answers: 104
you should try to take a sample that is sown in a tray and check the rate of emergence.
if it is, it is a seed problem
- 15/07/18, 15:36
- answers: 104
for carrots, I have some of the same concerns, but I put it down to my big soggy fingers and a lack of knowledge when it comes to covering the seeds. I've always had a bit of trouble getting them lifted, but once they've started I usually get beautiful ones without any ...
- 15/07/18, 14:53
- answers: 104
After long studies conducted on my problem of sowing beans I found the answer (in truth I read something about the forum I believe and I noticed the same thing at home, so I make it my own): I dug up a seed and found a kind of little white slug (and of course viscous) ...
