No, zon reduced the displacement to 2400 cc and replaced the soft tires ...Econology wrote:Woodcutter wrote:Illustration for the Silverstone GP Sunday 11/06: full load time this year = 71%, full load time last year = 59% ...
Impressing the difference ... zon flange the engines or it is the weather conditions + favorable?
Water injection competing in 80 years
- Woodcutter
- Registration: 07/11/05, 10:45
- x 2
- Moderator
- Registration: 10/02/03, 14:06
- x 11098
So, well, the engines are well restrained
ps: Saab's article is available but you have probably already read it via the news water injection by SAAB
Do a image search or an text search - Netiquette of forum
- Woodcutter
- x 2
- Woodcutter
- x 2
Hello
I just found a site that talks about the power of the engines depending on atmospheric conditions.
I think that the injection of water used in the competition engines of the 80s served to give the equivalent of the best possible climatic condition at the admission level.
http://www.problemauto.com/?612/Puissance-moteur
Mind-blowing on a car donated for 231hp, you get up to 50hp difference depending on the T ° and the Patmo.
- Woodcutter
- x 2
Concerning turbos (in F1 in the 80s and until 2005 in WRC) the water injection is used to cool the intake air as much as possible (heated when it is compressed by the compressor) to give it the greatest density possible.PITMIX wrote:[...] I think that the water injection used in the competition engines of the 80s served to give the equivalent of the best possible climatic condition at the level of the admission. [...]
"I am a big brute, but I rarely mistaken ..."
- Moderator
- x 11098
Water injection is now prohibited by the WRC regulations, but I didn't think it was authorized until 2005 ...
http://www.ffsa.org/pratiquer/france_auto/fa67.pdf
page 27 of .pdf right column
Hello
It is a fact that we go out more (maximum power) in cold weather at -10 than in summer at +30 and aircraft pilots know this. Performance increases in cold weather, but also for other reasons density air on the wings and on the propeller.
Now in winter consumption is increasing, all the vehicles I have used consume more in winter than in summer.
So be careful when talking about power and efficiency, the maximum power that an engine can give is one thing, but the energy that can give an engine with 1 liters of gas is another thing and ( generally) the design of the engine goes to the reverse of the powerful,
a 3-cylinder single cylinder engine with a long stroke would perform better than a 12-liter V3, but not very practical in use.
If I read the post it says that sucking in hot humid air (stormy) is unfavorable on the maximum power (and it is true) however with the panton we do exactly that of humid air in the engine and we save money and we also have less maximum power. Often we think that this is due to the restrictions and the hot air that we downstream, but also the vapor took a place of oxygen in the volume swallowed, so you can't put the same fuel load on it and you lose on maximum power.
Certain Pulling competition tractors, it installs a system to put the diesel very cold (to inject more)
Andre
PITMIX wrote:Hello
Andre
- Similar topics
- Replies
- views
- Last message
- 11 Replies
- 33560 views
Last message by Christophe
View the latest post
04/09/16, 19:12A subject posted in the forum : Water injection in heat engines: information and explanations
- 3 Replies
- 9599 views
28/06/16, 23:24A subject posted in the forum : Water injection in heat engines: information and explanations
- 25 Replies
- 24288 views
12/03/16, 03:18A subject posted in the forum : Water injection in heat engines: information and explanations
- 18 Replies
- 21601 views
07/10/17, 18:56A subject posted in the forum : Water injection in heat engines: information and explanations
- 35 Replies
- 54718 views
Last message by Macro
30/09/15, 08:34A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 62 guests
