the valves that rise all by themselves are nonsense ... it has been a long time since we abandoned the automatic valves for internal combustion engines ... why we continue to use them for compressors?
we have understood for a long time that for the admission of internal combustion engines it was better to mechanically control the opening of the intake valves ... we have not yet understood this for the compressors ... and yet the loss of energy is more serious than mechanical friction
conclusion it is necessary to make precise measurement on the existing machine! only measures can show the way to do better!
Liquid nitrogen generator engine
- Registration: 11/11/07, 17:33
- I learn econologic
- Registration: 03/04/18, 22:54
Re: Liquid nitrogen generator engine
Eric Dupont wrote:but I did the calculations
Can we see them?
- Registration: 13/10/07, 23:11
- x 40
i agree with the fact that the flaps that stand up by itself sound absurd(there is only observed the geo valve to be convinced) that's why I put valves, but it's true that if I calculated the air speed in the valves I did not conceal the pressure drop, you have an idea of how we could make ?
Eric Dupont wrote:I calculated the air speed in the valves
Let me see your calculations, I'm interested.
Eric Dupont wrote:i agree with the fact that the flaps that stand up by itself sound absurd(there is only observed the geo valve to be convinced)
a not very elegant way to ask geo to close its valve ... while it is only usefully participating in the discussion!
- x 40
he participates it's true, but as a ball. at least that way we stay on our feet.
the air speed at the valve depends on the speed of the piston and the surface ratio between the piston and the valve. after the pressure drop depends on the aerodynamics of the valve, a valve of the seat and the pipe. maybe we should do a test with water to see the flow of water according to the height of the fall, then transfer this to the gas assuming that it is incompressible, there are abacuses for waterfalls water and flows according to the shape of the orifice through which the water flows.
I agree that it is a trick optimized by increasing the number of valve, by reducing the speed of the piston and by improving the shape of the conduit, there is also the stroke of the valve with the height and the speed of opening ... all this was taken into account in the demonstrator.
Eric Dupont wrote:he participates it's true, but as a ball. at least that way we stay down to earth ..
and you allow yourself to treat me as a viper tongue ... you're even worse
I do not think more and will say no less
- Registration: 28/09/09, 17:35
- x 554
Eric Dupont wrote: maybe we should do a test with water to see the flow of water according to the height of the fall, then transfer this to the gas assuming that it is incompressible, there are abacuses for waterfalls water and flows according to the shape of the orifice through which the water flows.
But of course it is.
The boy hasn't gotten to the end of his machine.
- x 554
chatelot16 wrote:I do not think more and will say no less
The guy compares the thermodynamics of gases with water, so he's a perfect stupid and a gutter thermodynamicist.
You have to name things.
Eric Dupont wrote:he participates it's true, but as a ball. at least that way we stay on our feet.
Is it to reveal to the public your monumental scam that bothers you?
Or is it to remind everyone that you have oyster IQ and a heavy past?
I received some crisp information about you.
I'll be you, I'll mute it very quickly ... and advice: go back to school, open books ...
- Similar topics
- Replies
- views
- Last message
- 18 Replies
- 8135 views
Last message by Christophe
View the latest post
06/09/22, 00:50A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 13 Replies
- 7647 views
Last message by Janic
20/06/21, 15:14A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 42 Replies
- 30929 views
Last message by Lilieth78
20/05/18, 15:32A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 23 Replies
- 22029 views
Last message by Ahmed
27/02/17, 19:56A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 10 Replies
- 8650 views
19/10/16, 23:32A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Who is online ?
Users browsing this forum : Google Adsense [Bot] and 113 guests
