Hello and Merry Christmas everyone
http://www.youtube.com/watch?v=3XpBbMcl7Jk
Or Merry Christmas ...
http://www.youtube.com/watch?v=NDU4Z_BBkTA&hl=fr&gl=FR
Ok Did, my installation is not up to standard, at least not yet!
I am doing earthworks
and maybe I'll take the opportunity to install a Canadian well that will arrive in the garage, so ventilation ...
The heating engineer had warned me about the ventilation, but since I had not connected the air extraction from the water heater to the outside there was not yet a draft problem for the chimney.
A + Manu
Emission of smoke boiler Okofen
bidouille23 wrote:Slut,
A little question when you talk about the plate you talk about the crucible or falls and burns the pellet ???
If that's right, it looks like iron chew, a friend had the problem with his pellet stove.
What kind of granule do you burn?
Rate of dust?
Composition?
Dinplus?
Hi Bidouille.
Yes, I'm talking about the crucible.
Wood pellets product sheet.
These are not DIN +
Diameter 6 mm
Length 10 to 30 mm
PCI 5100 Wh / kg [calorific value]
MVA 650 kg / m³ [density]
Efficiency 89%
Humidity 8% max
Ashes 1% max
The next delivery I would order DIN + to see if like dirk pitt it solves the clinker problem
A + Manu
- Registration: 21/06/09, 01:02
- x 2
Hello ,
Did I correct for coke, it's coal coal not wood ...
Coal is a rock ...
http://www.techno-science.net/?onglet=g ... ition=3407
For what is pellet:
Din + is not the official certification awarded by din certco which is DINplus
http://www.dincertco.de/en/wood_pellets ... ilers.html
http://www.badgerpellets.com/fr/p/certi ... n-din-plus
http://www.piveteaubois-pellets.fr/web/ ... -plus.html
At the same time your pellet is inside what is original is that it marks din + instead of din plus ???? what is the point of having this certified if you do not note the correct certification on the package ??? or ... it's just not certified ... note it's simple here the list of sellers to certify;).
http://www.beuth.de/beuth/owa/DCOWeb.DC ... _name=PROD
you just have to look for your manufacturer in it;)
dirk pit is not necessarily iron chew, molten lignin is as crystallized on the surface, not iron chew, at least not the one there is
http://www.ragt-energie.fr/fr/biocombus ... o-brut.jpg
Indeed if you had a reverse draw everything is explained.
Assessment, well good continuation of work especially ...
Coal is a rock ...
For what is pellet:
At the same time your pellet is inside what is original is that it marks din + instead of din plus ???? what is the point of having this certified if you do not note the correct certification on the package ??? : shock:: mrgreen: or so ... :) it's just not certified :) ... note it's simple here the list of sellers to certify;) ...
1) I confirm. I had developed this one day, I do not know where.
The label is the logo.
It has value only by specifying the approval number of certco.
So a "real" Dinplus pellets is the CERTCO logo + certficiation n ° tant et tant (on the packaging - bags - or on the invoice in the event of bulk).
Everything else is marketinbg and sometimes deception
My supplier, actually certified, writes Din +. In Germany, this seems fairly regular on the Internet. I admit that I don't know why they sometimes write Din + instead of Dinplus!
In France, the appellation "quality Din + "has blossomed. Almost always, these are non-certified producers. Since they don't write" certified ", they don't really lie. They" claim "that their product is the same quality as the" real "Dinplus .
And as they write "Din +", it is not Dinplus, and CERTCO cannot sue them ...
So in France, beware of these two terms and their reconciliation! In general, this signals fraud. There are only a few producers actually certified in France.
dirk pitt wrote:No pressure sensor on my boiler. I believe that it is only those equipped with measurement in the home.
Is that so ? I thought it was there automatically. But it is true that the equipment has not stopped moving. The hearth temperature sensor was an option and was then installed as standard. The pressure switch, I don't know? Notice to new owners?
I believed that "depression" security had always been there. The "pressure switch" is on the left, next to the plate. And the air "intake" pipe is a small pipe which opens into the left and upper part of the door frame. Warning: by cleaning and emptying the cenrider, it can be clogged; with fault (the boiler finds that the depression in the fireplace is insufficient). The very type of "stupid failure"! (for those who have this equipment).
- x 17
Did67 wrote:Have you checked that it's real Dinplus ???
There must be the certification number and from the CERTCO site, you check if the producer is actually certified. Or if he only claims it!
The Badger is indeed Dinplus certified. It's Belgian pellet.
http://www.badgerpellets.com/fr/news/vi ... es-pellets
http://ebookbrowse.com/certificat-din-p ... d388588585
Re: Smoke Emissions Okofen Boiler
Hello,
I have a similar problem and you might be able to help me.
I have an okofen pellematic smart boiler and it is constantly failing "smoke wind", I find in the fireplace full of pellets not burnt, soot etc.
I soon thought that the ducts were obstructed but I did not find anything, the fan seems to work properly ..
It seems that there is a draw problem (big white smoke, muffled fire).
It started during the first cold weather of this winter and since impossible to make it work so much to tell you that it is urgent: /
Thank you in advance for your answers
Cdt
Cdt
Back to "Heating, insulation, ventilation, VMC, cooling ..."
Who is online ?
Users browsing this forum : No registered users and 198 guests
