Hello Phil
Suction in a diesel is only air and the quantity is so high that a little more or a little less does not change much,
the little bit that goes into the reactor is a small percentage compared to the 600 kilos of air per hour that an engine of this displacement can swallow. So 4 or 5 kilos of water + air, in this storm it is negligible.
As for the plugs it is not an obligation you make a different assembly, but once assembled you can no longer go to remove the rod.
Although if the assembly is well done you don’t have to turn it inside
as long as you respect the maximum clearance 1,6mm and minimum 1mm
For a large engine it is preferable 1,5 to 1,6 and a rod of 100mma 120mm the dimensions are not critical, the outlet pipe which goes to the inlet of the turbo must be large enough from 25 to 30mm it must not restriction, restriction must only be between the rod and the reactor
You will notice that on all SPAD assemblies we rarely see a multireactor, there is nothing to observe the output copper pipe, it is always 14mm. I think it goes to the simplest.
You will calculate a large reactor is the equivalent of 2 small in residual area.
Rather takes care of the bubbler and the piping and the suction in front of the turbo, this is where it happens, in the reactor if it receives heat, depression, and gas speed, it always works, even with different dimensions and different materials. .
rech. motor + 200 cv pantonisé info
Good evening André
A rod between 19 and 25 mm is considered a large reactor
the reactor tube must be 3mm longer than the rod to reach a set of 1,5mm. You take what you find in the trade, and you adapt ..
CALCULATION
tube diameter: 23 mm 415 mm2
rod diameter: 20 mm 314 mm2
difference: 101
tube diameter: 18 mm 254 mm2
rod diameter: 15 mm 176 mm2
difference: 78 mm2
tube diameter: 28 mm 615 mm2
rod diameter: 25 mm 490 mm2
difference: 125 mm2
Perhaps it is necessary to provide the rod 120mm long rather than 100mm on a large reactor since we are just inside the reactor volume compared to the assembly of 2 small.
good night
a + phil 14
CALCULATION
difference: 101
difference: 78 mm2
difference: 125 mm2
good night
a + phil 14
Hello Phil
for the thickness of the reactor tube it is preferable, practical question that it is of this thickness, less problem to weld it, as it is a constant speed motor the temperature will eventually pass through the wall
When you are going to weld on the exhaust, push an iron rod or a tight pipe in it, place where you are going to weld it prevents the shrinking, of the stainless steel pipe because of the welding it will save you from passing the file after, don't forget to take it off when it's still hot, sanas what you're going to fight with.
550c is a song for this material.
good evening everyone
Having no answer, I feel a little concerned by a post from a member of the forum who said that some asked for more information than he did to advance research on the pantone process.
It is true that I have asked a lot of questions lately and I take this opportunity to thank André among others for all the advice he gave me.
Having only had time to make a bubbler, I thought it would bring nothing new by showing it in a photo.
I think I will have more time available this winter to finish my first assembly on my tractor. As soon as it is finished I will put some photos as well as the results obtained.
PHILL 14
PHILL 14
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 146 guests
