Solar engines to build and experiment
Renewable energies except solar electric or thermal (seeforums dedicated below): wind turbines, energy from the sea, hydraulic and hydroelectricity, biomass, biogas, deep geothermal energy ...
Moderator
Moderator
Registration: 10/02/03, 14:06
x 11098
by Christophe » 24/09/08, 14:55
In the lineage of the Minto Wheel but in addition "affordable" here are some ideas of solar motors to test!
A) Principle of the "2-stroke" expansion solar motor:
http://www.genuineideas.com/HallofInven ... wheel.html
B) A mini demo minto wheel: http://www.genuineideas.com/HallofInven ... movie.html
C) The thermoscopic balance:
Thermoscopic Balance
by Geo. Mr. Hopkins
From Scientific American, Feb 26, 1887 p134
The action of this instrument is due to the fact that the liquids evaporate in a vacuum. A small amount of heat is sufficient to vaporize the liquid to the extent required to secure the desired action. The instrument is provided with a glass tube at right angles, and having a bulb blown on each end. The tube and the bulbs are partly filled with water, and a vacuum is secured by boiling the water in the bulbs before sealing them. The center of the tube is furnished with V-pivots, which rest in bearings in the top of the forked column. The column also supports a metal screen, which is bright on one side and black on the other. Two pins project from the shield, to the movements of the glass tube and the bulbs.
When the instrument is in use, the screen is placed on the source of heat, and when it is radiant heat strikes the bulb which is unshielded by the screen, the water in that bulb is vaporized, and sufficient pressure is produced to drive the water the bulb behind the screen. When a little more than half of the water bulb, the upper bulb preponderates. The tube and the bulbs are supported on their pivot so as to secure unstable equilibrium, so that, when the upper bulb begins to go down, it completes its excursion at once, and exposes the full bulb to the radiant heat, at the same time carrying its empty bulb behind the screen, where it cools. The transfer of the water from the full bulb to the empty one now occurs as before. This operation is being extended to the action of radiant heat. The oscillations may be quickened by the presence of the bulbs from the screen, and still more rapidity of action by condensing the heat of the condensers or reflectors.
chrisleblay
I understand econologic
Registration: 16/06/07, 01:35
x 4
by chrisleblay » 25/09/08, 04:16
Here is a very simple little that uses the mirrors of old computer hard drives as concentrators:
http://www.youtube.com/watch?v=qU48ckoU ... re=related
chris
  • Similar topics
    Replies
    views
    Last message
Back to "hydraulic, wind, geothermal, marine energy, biogas ..."
Who is online ?
Users browsing this forum : airpluso and 129 guests
