Hello,
I would like to know what material you used for the tube from the reactor outlet to the engine intake, as seen in the photo below.
Since it looks like plastic, I wondered if it supported the temperature of the steam.
Jean-Do
Pantone engine Opel Corsa 1000
Bonjour à tous
The best specially loaded plastic pipes do not hold more than about 250 ° without crepe or melt. It is a temperature "easily" obtained on the body of the reactor at its outlet. (The pipe boils at the level of the clamp on the outlet of the reactor even if it can resist a moment a few cm further).
In flexible hoses able to hold, you have silicone (up to 350 ° when the pressure remains low). After it seems to me that all the other solutions are metallic.
Reason is the madness of the strongest. The reason for the less strong it is madness.
Hello Jean-Do57
For example Venair (no action at home ):
Hello Patrick,
I just published a post on a montage PMC on gasoline engine whose management is very close to your Corsa. I will be very flattered if you had a few minutes to devote to my editing
It is here:
https://www.econologie.com/forums/post94371.html#94371
Thank you in advance for your constructive criticism!
Jean-Christophe
It is here:
Jean-Christophe
- Similar topics
- Replies
- views
- Last message
- 6 Replies
- 8941 views
Last message by denis
View the latest post
08/07/19, 15:09A subject posted in the forum : Water injection in engines: montages and experiments
- 5 Replies
- 13392 views
Last message by Flytox
06/11/17, 23:41A subject posted in the forum : Water injection in engines: montages and experiments
- 6 Replies
- 11230 views
Last message by gildas
30/03/17, 09:10A subject posted in the forum : Water injection in engines: montages and experiments
- 27 Replies
- 29971 views
Last message by chatelot16
31/07/16, 11:00A subject posted in the forum : Water injection in engines: montages and experiments
- 3 Replies
- 8624 views
Last message by jrneco
11/03/16, 20:29A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 173 guests
