Hello
for some day I discovered traces of white in my carb (on a doping with water), it happens that it blocks the needle.chez us the water is not limestone, rather acid.
could anyone tell me what knows or brought me a solution !!!
zac
carbide problem
Try to put demineralized water already ... it costs a little more expensive than tap water but it remains very affordable (0,40 Euro per liter a week ago at home)
Otherwise you can clean your carb with a product made for, or releasing at worst it should unlock your needle ...
The white traces are oxidized aluminum, no?
SixK
SixK
Optimists invented airplanes, parachutes pessimistic. George Bernard Shaw.
Thought personal, I understand better why the big bosses invented the golden parachute.
hi Zac
I also have a carburettor that I made all brass that mouth also,
the small hole of the jet, I modified with a big jet with a larger air emulsion, for the wealth I play with the level of the tank which feeds the carburettor, I walk only with rainwater it passes to the through a small skidoo snowmobile fuel filter.
- Similar topics
- Replies
- views
- Last message
- 5 Replies
- 7382 views
Last message by Flytox
View the latest post
01/03/09, 22:05A subject posted in the forum : Water injection in heat engines: information and explanations
- 6 Replies
- 13921 views
Last message by jime
06/05/08, 12:26A subject posted in the forum : Water injection in heat engines: information and explanations
- 38 Replies
- 34433 views
Last message by Christophe
01/01/09, 14:55A subject posted in the forum : Water injection in heat engines: information and explanations
- 14 Replies
- 12089 views
Last message by Thibounet
03/03/07, 11:44A subject posted in the forum : Water injection in heat engines: information and explanations
- 1 Replies
- 6103 views
Last message by PITMIX
03/11/05, 22:43A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 164 guests
