There is still a question I ask myself about water doping. Could this not cause premature engine corrosion?
André, you already demote an engine doped with water I imagine ;-) what does it give? clean, dirty, rusty?
and for the exhaust?
Water doping
Hello, answer Abyssin3
For diesel I can not comment only on the exhaust, I did not constster a difference on cleanliness with or without reactor,
only more soot on the reactor than in the parts of the exhaust pipe, because I had tended to send water too quickly before it was hot, I have remedied the new assembly.
For the assembly of the petrol engine, after a few months of use I had to dismantle the intake manifold, on a V6 it is compact and we partially see all the valves, the tubing was very clean as well as the light deposit valves gray on the mushrooms, the exhaust also gray white, the candles rather white.
The only corrossion I had was in the carburetor reducer that I used 3 / 8-1 / 4 in cast iron which I replaced with stainless steel
The copper outlet pipe tends to become black oxidized inside
But for the engine it's been this spring that I ride with that.
what is needed is to make the system operational only when it is hot, this avoids sending water in droplets.
- Similar topics
- Replies
- views
- Last message
- 7 Replies
- 21610 views
Last message by Projéthée
View the latest post
07/11/11, 22:47A subject posted in the forum : Water injection in heat engines: information and explanations
- 448 Replies
- 288369 views
Last message by grinchou
24/10/19, 08:02A subject posted in the forum : Water injection in heat engines: information and explanations
- 5 Replies
- 22205 views
Last message by Flytox
23/03/11, 21:43A subject posted in the forum : Water injection in heat engines: information and explanations
- 55 Replies
- 102202 views
Last message by Capt_Maloche
23/09/15, 16:05A subject posted in the forum : Water injection in heat engines: information and explanations
- 14 Replies
- 33555 views
Last message by zorglub
26/02/10, 16:39A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 80 guests
