by welding points of course !!!
not serious! it is centered by welding tack at 120deg or differently if you find better (knowing that the welding spots are very simple to make)
issue any beast on the rod
- I learn econologic
- Registration: 23/04/05, 20:23
- pinkfloyd30
- Registration: 30/08/05, 12:04
ahhh i also said to myself, thank you, but does the fact of passing current through the rod (because there is when we do welding is not it ???) does it will not create an imbalance in magnetization or something like that
"How can we not admire the force that man uses to saw the branch on which he is sitting ???" Jean-Marie Bigard
No danger if you have taken the precaution to place the accessory A
on the reactor
when soldering (very important: aligned
ds the direction of the reactor cord side arrives bubbler)
As well as accessory B
on the welding station (NE direction)
Caution: do not confuse the 2 (can cause serious injury
to the experimenter's brain due to released radiation)
Object A:
http://titwane.free.fr/div%20grigri9.jpg
Object B:
http://titwane.free.fr/div%20grigri6.jpg
: Huh:
on the reactor
Object A:
Object B:
: Huh:
- pinkfloyd30
ok merci , I had hesitated to answer, I could have gone even further. By cons, it has nothing to do with the subject but, do I have to leave the fuel or then I have to manage the intake with the valves if I mount the reactor on a moped? (not because it has to be loud to speed up with valves but hey, at least we can let go of the handlebars without slowing down )
- Similar topics
- Replies
- views
- Last message
- 15 Replies
- 34210 views
Last message by FPLM
View the latest post
09/03/10, 09:56A subject posted in the forum : Water injection in heat engines: information and explanations
- 1 Replies
- 4045 views
Last message by hoedic
15/09/05, 08:07A subject posted in the forum : Water injection in heat engines: information and explanations
- 1 Replies
- 3624 views
Last message by Christophe
12/09/05, 21:19A subject posted in the forum : Water injection in heat engines: information and explanations
- 3 Replies
- 5668 views
16/12/04, 19:36A subject posted in the forum : Water injection in heat engines: information and explanations
- 4 Replies
- 6546 views
27/01/05, 09:09A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 154 guests
