citro wrote: Nice presentation bham.
Thank you citro.
citro wrote:I would remind you, however, that metal joinery with thermal break is far from being widespread.
However, I question the 100% efficiency of this kind of carpentry. Such a section with thermal break is in fact the assembly of two "half" sections linked together by a piece of hard plastic. But we must not forget that the air present between these two "half" profiles is in contact with a "hot" profile and a "cold" profile. The air is therefore hot on one side, cold on the other with a dew point in the middle, which can come into contact with the interior "half" profile in very cold exterior conditions, destroying the effectiveness of the bridge break. thermal. So for me, it's not the best.
citro wrote:I recently discovered super insulating joinery combining high-performance glazing with wooden joinery plus aluminum exterior cladding. These are very high-end ...
I just bought it, with triple glazing (currently at the same price as double glazing). The insulation coefficients give Ug (glass) = 0,6 and Uw or Uf (window or window thermal resistance) = 0,95.
Knowing that U = 1 / R, R is = 1,05 is the equivalent of 6,5 cm of expanded polystyrene. So perfectible from a thermal insulation point of view but already very good for a glazed surface, which limits the importance of the thermal bridge that a window constitutes.
I am counting on the tax credit to lower the bill ...
For information, the French thermal regulations, RT 2005, impose, in new construction, a level of facade insulation which requires the use of at least 4mm / 16mm / 4mm double glazing with low-emissive glass to obtain a Ug coefficient <or = at 1.5
