bjr
I would like to know if I could modify my 106 1l1 with the pantone system?
and if ever there are any plans to help me.
and I also ask myself how does it make the engine run as well while the air at adm is hot and humid with the water vapor?
Doping adaptation of motor 106 1l1 monopoint
young mechanic boy who is interested in everything!
Hello Lagarde
It is not sure that you will find plans quite done ... What is your engine, gasoline, diesel? Do you have room under the hood, ideas on the type of installation you want / can do?
(bubbler, SGS, etc ...).
In terms of swallowing hot, humid air in the engine, it does not do much visible when it does not work (except decrease pollution) but when you have found the right configuration, you reduce your consumption, your pollution and in some cases you gain some power.
Reason is the madness of the strongest. The reason for the less strong it is madness.
yes there is room c is a single-point fuel injection.
on the type of instalation that I want I do not know because I did not really understand the different montages if you can explain me
gv
the buleur I see a little editing but I do not know the differences between all
gv
Hello Lagarde
From the outset it's not super obvious, you can hardly afford to read many post to start having clear ideas on how to approach the baby.
Use the "Search" window and take the time to assimilate the experience of others .... many relevant answers await you inside .... after these readings you will be able to make some choices to orient your editing and the forumI will be happy to help you in your achievements ... good readings.
See you soon.
See you soon.
Hello
You can read these articles that are very useful
https://www.econologie.com/plan-et-conse ... -3727.html
https://www.econologie.com/realisation-d ... -3728.html
https://www.econologie.com/generateur-de ... -3735.html
- Similar topics
- Replies
- views
- Last message
- 0 Replies
- 4521 views
Last message by cyanoline
View the latest post
24/06/05, 00:12A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 260 guests
