Pantone on mower: possible assembly or not?
Hello to all I start by mounting the pantone system as is on a small mower, it starts well and it takes many turns. On this system I pass the exhaust gas in the bubbler to make the liquid bubbling and warm it up. In any case, I understand that I have to think a little change the system by passing a tube of the exhaust in the bubbler to warm it up and add a fresh air on the bubbler, I think it could work even better if someone could tell me what he thinks I leave a little drawing that shows a little my idea
I'm tired of paying too expensive gas and I've always dreamed of driving with water so that's where I'm going
- Moderator
- x 11062
Hello,
The heating by the direct exhaust in the bubbler is not very effective and overpressure can be a disadvantage!
Does your bubbler contain only water or water + gasoline? In the second it is not worth the heat because you will not consume 1 gram of water ...
Otherwise, your image does not appear ... so I deleted the link.
Try to convert it to .gif if possible.
then in my bubbler I wanted to use a mixture of water and petrol 50%. In this case you think it is not useful to heat the bubbler but then the water is useless.
If not for drawing I use paint but I do not know much about computer science should use what software?
well, thank you for your advice.
mic42 wrote:If not for drawing I use paint but I do not know much about computer science should use what software?
Well if you only have that, continue with paint, but when you record "Save as", selected GIF
"Thinking should not it be taught in school rather than to make learning by heart the facts that are not all proven?"
"It's not because they are likely to be wrong they are right!" (Coluche)
- Moderator
- x 11062
mic42 wrote:then in my bubbler I wanted to use a mixture of water and petrol 50%. In this case you think it is not useful to heat the bubbler but then the water is useless.
Yes water is useless in a heated bubbler containing gasoline because the gasoline will evaporate well before water ...
Thanks to del for the explanation
https://www.econologie.info/share/partag ... uxVWBm.GIF
https://www.econologie.info/share/partag ... UFybtL.GIF
here are two drawings that should appear
For the first c is the assembly that I realized on the lawn mower it works well but I noticed that when I debranche the diver echapement it worked much better.
On the second drawing is the assembly that I would like to make the run passes in the bubbler and the bubbler has a free set.
I would like to have your opinion on whether it can work or not.
thank you all
thank you all
- Similar topics
- Replies
- views
- Last message
- 6 Replies
- 6537 views
Last message by bleusideral
View the latest post
29/04/18, 19:49A subject posted in the forum : Water injection in engines: montages and experiments
- 27 Replies
- 30224 views
Last message by chatelot16
31/07/16, 11:00A subject posted in the forum : Water injection in engines: montages and experiments
- 1 Replies
- 5652 views
Last message by Flytox
01/12/15, 22:07A subject posted in the forum : Water injection in engines: montages and experiments
- 41 Replies
- 54252 views
28/02/14, 18:43A subject posted in the forum : Water injection in engines: montages and experiments
- 21 Replies
- 32774 views
Last message by dede2002
17/02/14, 21:05A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 89 guests
