I inquired about the price of the pump that meets EN 1717 standards. Admittedly, it is not cheap, around 1300 euros.
it makes the return on investment even more difficult.
Are there any of you who installed a pump without the total overflow system, or who would tinker with its overflow to meet standards at a lower cost?
When I take a closer look at the proposed systems, it is actually a flushing system that is installed under the pump.
This could possibly be DIY yourself.
What do you think?
EN 1717 standards pump prices
- Éconologue good!
- Registration: 30/09/06, 21:23
Hi Val56,
the price you mention is one of the lowest on the market, and HT !!
(for "installer" prices) ..
yes ...
yes ...
on the other hand, I opted for this system (the simplest and the least expensive that I know!) but just to "do well", to reassure a possible controller, because there is no question for me to inject chlorinated city water in my cisterns .. !!
because personal in view of my reserve and my consumption .. I am not ready to be dry .. !! , so the problem does not bother me ..
but, must it be said that these automated pumping modules are only "interesting" in a city water changeover hypothesis> <relatively frequent EDP ...
because if you have a well-dimensioned installation with safety margin (in volume) and that you only risk possibly being dry 1 X or 2 / year ... does the investment of this type of material is justified .. ??
if you want to realize a system of total disconnection yourself and not expensive, there are 2 possibilities that (personal) I put forward:
or, city water overflow in the EDP tank.
(if we accept city water in the EDP tank ..)
or, the 2 arrivals (mains water / EDP) placed side by side in //, facing an internal circuit departure connected to one OU the other inlet via a flexible ...> in this case, the changeover is manual to reverse the flexible from one inlet to the other according to ... and the 2 waters pass through the same internal circuit, but the 2 networks are never connected to each other.
I hope I have been clear enough ..
cordially
yes ...
Are there any who use this solution?
yes ...
cordially
well hello to you !! ...
thank you for your answers p'tit pierrot
Why would it be a problem to put city water in the rainwater pit?
If I did, I would supply it with a solenoid valve which would open just enough to pass a few dozen liters (tempo), so as not to obviously fill the tank. Which would be a mess at the first downpour.
Your second solution by manually reversing the internal hose does not meet the standard in 1717, since when you are going to switch it from the rain circuit to the city circuit there is a risk of residual flow, therefore of dispersion of bacteria.
I'm going to tackle the first solution: overflow into the rainwater recovery pit.
But I do not know how to go about it Should I speak to a professional or is it simple to do by a handyman that I am?
Thank you for enlightening me on this subject
- Éconologue good!
Hi Val56,
if you inject city water (chlorinated) in the EDP, you will modify the physico-chemical characteristics of the EDP ... probably very good before that ... (if concrete storage ..)
pity ...
this system is very easy to set up ..: by pulling the pumping pipe (PE diam 32), you pull a second pipe (PE diam 25) in parallel towards the tank to make your "emergency supply" in city water ..
and it only costs you that second hose and a valve or solenoid valve if you prefer ...
for the second solution, just at the outlet of the flexible pipe, install an EA pollution control valve there so as not to have this "residual return".
to meditate ... to improve to everyone's taste ..
cordially
pity ...
cordially
- Similar topics
- Replies
- views
- Last message
- 44 Replies
- 114805 views
Last message by Meszigues3
View the latest post
15/02/17, 23:02A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 64 Replies
- 56489 views
Last message by Macro
22/06/12, 11:36A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 8 Replies
- 16544 views
Last message by zorglub
24/02/10, 08:47A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
- 44 Replies
- 35674 views
Last message by Christophe
11/03/16, 20:03A subject posted in the forum : Water management, plumbing and sanitation. Pumping, drilling, filtration, wells, recovery ...
Who is online ?
Users browsing this forum : No registered users and 112 guests
