Thank you for your Caracole compliments.
Recovery engines?
yes, we find (or rather found, easier to find) this type of engine on washing machines,
They are manufactured by Polymotor (Italy), I still use them today to make small two-bladed wind turbines from 1,10 to 1,45 m in diameter. (I have also been working for a long time on a dynamic balancing monopale, which I can not even manage to balance correctly, the magnets in phase opposition, may help me to follow),
So, it's a permanent magnet motor (like a bicycle dynamo) so DC, it can be a motor or a generator, no matter what, here is its motor plate:
https://www.econologie.info/share/partag ... moteur.jpg
For info:
Supplied with 10 Volts> approx 600 rpm
Supplied with 20 Volts> approx 1175 rpm
Supplied with 30 Volts> approx 1750 rpm
Supplied with 60 Volts> approx 3750 rpm
We can go up to 15 rpm with 000 Volts DC (be careful, direct current is very, very dangerous above 48 volts)
Its original axis is either 9 or 12 Mm
I think I have said everything about this engine.
About the theory of Mr Hatem, theory which I find rather interesting, the Film which I did not know, presented by our comrade "Energy" is all the same very rich in explanations.
Hang in there ....
"HATEM" experience following and photos
Hello everyone,
A little word of encouragement for the LRH system experimenter,
It seems to me that the small, functional magnet motor visible on PESWiki (positively replicated), in my opinion, appeals to the principle of de-gravitation.
I started a model with the magnets I own, I think I will do the first test during the weekend.
The set-up is visible HERE
A + + +
A + + +
Every minute that passes is an opportunity to change the course of your life.
YouTube page, Dailymotion page, Picasa album, personal Pages, Viktor Schauberger
quartz wrote:Hello everyone,
I agree with the encouragement
on the other hand the principle of degravitation of LRH is too vague
to be put to all the sauces of more its philosophy
is not based on any convincing experience and even less
on a relevant observation of physical phenomena
but rather on a bad interpretation of the transformation
energy and kinetic energy in particular
on the other hand, the replication of CLaNZeR is very real
it remains to find plausible explanations !!!
I understand your reluctance Tagor, and I understand it.
I think I'll let go of my bias in favor of the LRH hypothesis.
I am firmly determined to attempt a replication of the CLaNZeR system,
so if I manage to make the bouzin turn I would turn around to get as much juice as possible.
But to see the videos it is absolutely necessary to have inertia on the two rotors, especially on the small one, and a high differential speed is required.
In addition, in the LRH replica attempted in particular by Naca, the discs rotate in opposite directions, two by two (which seems logical at first glance), while on small engines it is the other way around.
From where a double differential speed, and it is all the same clearly stated by LRH high differential speed from where loss of attraction more rapid.
But hey, I don't come back to the charge, we will play with the models, there will always be time to find explanations afterwards.
A + + +
A + + +
quartz wrote:But to see the videos it is absolutely necessary to have inertia on the two rotors, especially on the small one, and a high differential speed is required.
yes the speeds are relatively high
So much inertia: this seems to me to be the key
of the success of this system
at one point the magnets are found in opposition
phase => hence a permanent imbalance => hence acceleration
this point, it may be difficult to keep it
but once reproduced it may be possible
to control it by microcontroller
good luck
it seems to me that it is very promising
A + + +
- Similar topics
- Replies
- views
- Last message
- 6 Replies
- 11598 views
Last message by jippy13
View the latest post
16/04/12, 19:57A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
- 1 Replies
- 14370 views
Last message by jonule
13/08/08, 10:36A subject posted in the forum : Innovations, inventions, patents and ideas for sustainable development
Go back to "Innovations, inventions, patents and ideas for sustainable development"
Who is online ?
Users browsing this forum : No registered users and 131 guests
