Complexity to find the right answer
- Moderator
- x 11060
Touafé for the legend, I thought I would do just after your remark, it will be done tomorrow morning
- Misterloxo
- Éconologue good!
- Registration: 10/02/03, 15:28
- x 1
- Registration: 12/01/07, 08:18
- x 4
gegyx wrote:It is the fable of the ten oarsmen ....
For your way of surfing, it must be as you say ..
In the link that interests you, you only have to click on the small horny page, which is at the end of the line. You will then fall on the first message, which you have not yet read (If you are logged in under your username, and without having emptied cookies).
Ha bin here, I learned something that will save me time
Hello,
Flitox wrote,
No need to use another text editor, you select all your message, then right click "copy" before "Preview" or "Send", and your message will be saved in temporary memory, ready to be "Paste" in case ...
Flitox wrote,
That day, in the middle of a battle, I had to redo my post 3 times, each time I did "Preview" the message was lost body and goods. I had to re do it on a text file copy it and send it direct for it to work. So it was not so much in sync with the discussion ....
Besides, when I do a bit long post, I got into the habit of saving it to a text file before doing "Preview". It allows not to repeat it too often ....
Hello fc89
The problem with this solution is that by previewing you notice some spelling mistakes, jokes etc ... and to correct you will use the copy paste again, so lose the whole text again, so at the end of x manipulations the slightest inattention and you have everything! So to secure the manipulation, you have to save .... on a text file etc ...
fc89 wrote:No need to use another text editor, you select all your message, then right click "copy" before "Preview" or "Send", and your message will be saved in temporary memory, ready to be "Paste" in case ...
Reason is the madness of the strongest. The reason for the less strong it is madness.
Go back to "The bistro: site life, leisure and relaxation, humor and conviviality and Classifieds"
Who is online ?
Users browsing this forum : No registered users and 159 guests
