Pantone ULM engine?
Edits and changes to engines, experiences, findings and ideas.
Other
Pantone engine Researcher
Registration: 17/03/05, 02:35
x 12
by Other » 08/11/07, 02:09
Hello
In both cases, the efficiency in terms of kilos thrust / cv engine is an important factor.
Very little research is done on the propellers of small planes
It's a bit of a let go at the discretion of small manufacturers
some great MaCCauley, Sensenich, Hartzel for the variables
then all the wood and composite propellers, which is a small market..Just look at the serial numbers on MaC Cauley since the 50s to see that it is not millions of propellers produced there. are still 5 digits.
I wouldn't want to disappoint you, but the thrust measurement on a propeller is not indicative of performance on an airplane
it only gives us a static indication.
Very rarely propeller manufacturers use this method of measurement on propellers, I also work in this field.
For example, a ULM pilot who came to the field with Rotax 80hp ULM and a scale, to make comparisons
with my Lycoming 140 hp engine and large propeller.
on the test with the scale attached it had more traction than the Lycoming :| ..
Then take off side by side, he only accelerated faster
but after 300 meters I lost it in the fog autand to climb, (1400 feet / minute) the speed we are not talking about almost double.
The bottom line is that a low pitch propeller gives more static traction on a scale, while a high pitch propeller becomes effective when the plane has picked up a certain speed.
the efficiency of a propeller is measured when cruising when it gives the least possible slip.
André44 :D
privateer69
I discovered econologic
Registration: 07/11/07, 10:58
by privateer69 » 08/11/07, 09:21
Hello and thank you for your answer.
But let's compare what is comparable ... I am not trying to transform a Rotax 912 into a Lycoming 140cv ...
My goal is to improve the performance of a propeller and so for the same machine:
- either to improve the performance of the beast
- or to switch to weaker engines
Info that I had forgotten, I was received four years ago at ONERA for this research; their response was:
- we don't have a budget for independent researchers
- to do is to demonstrate
Finally, a propeller is a wing which turns, its lift becoming its thrust. With a good profile we have a good zinc, with another we have a stone (no, no, I do not think of any machine that I have driven ...).
voila, things are progressing a little bit, I continue!
Sic forecourt magna
User avatar
Cuicui
Registration: 26/04/05, 10:14
x 6
by Cuicui » 08/11/07, 09:33
titus02 wrote: the improvement of the technology in matter of electric accumulator allows it, or could it
allow to fly an electric ULM?
The Silent AE (electric propulsion microlight) is marketed.
User avatar
Cuicui
x 6
by Cuicui » 08/11/07, 09:49
Cuicui wrote:
titus02 wrote: The Silent AE (electric propulsion microlight) is marketed.
Oops, no, I don't think it's released yet, but it flies well. There are also other models. Type "electric ulm" in Google
  • Similar topics
    Replies
    views
    Last message
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 242 guests
