Hello,
after falling on a forum where we talk about the pantone process, someone says it does not work. off I am very interested in this method.
hence my qestions before embarking on the dismantling of my car:
- is there a real efficiency and a decrease in pollution?
- is there really a reduction in fuel consumption?
Thank you for your answers.
Kind regards.
General information on the pantone process
- Moderator
- x 11060
To get started with pantone, here is a "reference" link:
https://www.econologie.com/wiki-moteur-p ... hp/Accueil
- Moderator
- x 11060
To see apparently it is not enough ... it is necessary to read a little in detail do not you think?
Do you think we would be so much on this forum to experienced if there was no result?
Go and give a last link:
https://www.econologie.com/citroen-zx-td ... es-70.html
Re: General info on the pantone process
tito wrote:- is there a real efficiency and a decrease in pollution?
hello and welcome
Go home Wednesday afternoon we rode one on a toyota hiace you can do all the test and the measures you want.
Said the zebra, freeman (endangered breed)
This is not because I am con I try not to do smart things.
if you live in the meeting, it'll be hard ...
Are there any people around Isère (Ain, Savoy haute savoie rhone) or Marseille who would like to share with me his modifications on his car?
Hello
move to open a hood and see (what we can see the water tank) the rest is incorporated into the exhaust pipe all covered with insulating wool and aluminum foil, all that I showed practically do not see nothing.
What you need to do is the full stopper and go with the priairaire to make a 100km 200km highway and you even refuel at the same place, With a measuring cup count the water consumed, take out ta calculator, you saurras something ..
For pollution you have enough control points in France ..
All these tests must be done motor support, no need to make measurements on city and motor in slow motion you will not measure much ..
20% is relatively easy but more than 30% asks more fine ..
Hello Tito
As Pitmix says, you have to try.
Between a good machine that consumes and pollutes much less and a series machine, there is time, focus, understanding, patience, gathering information from experienced, adaptations necessary to his machine .. ..but no miracle and universal solutions.
So good mechanics.
So good mechanics.
Reason is the madness of the strongest. The reason for the less strong it is madness.
- Similar topics
- Replies
- views
- Last message
- 18 Replies
- 11131 views
Last message by phil 14
View the latest post
08/10/05, 23:25A subject posted in the forum : Water injection in heat engines: information and explanations
Go back to "Water injection in heat engines: information and explanations"
Who is online ?
Users browsing this forum : No registered users and 156 guests
