Well there is no harm, it is especially for your work that I say that ... it would be stupid if all the photos disappear overnight. Besides, it just happened with an equivalent of imageshake.
In addition I am not sure that the hosting on imageshake is not limited in time ... after X months: nothing more ...
Pantone mounting PATROL 3L3TD
- Moderator
- x 11059
Hello
Beautiful editing
the layout of the reactor is excellent, the second assembly will capture more heat at low speed.
The water level control will be chaotic because of the pressurization of the bubbler with the turbo.
to operate in this way you have to put everything at the same pressure including the supply water tank.
It would have been preferable to make a simple air vent for the bubbler and let the engine slip through the bubbler
If the engine air filter does not make enough restriction, (depression) you can test a simple restriction, but the ideal is a venturi which does not penalize you too much.
Let's say that your assembly is well designed, as well as the layout as the manufacturing, you can easily make minor changes, without modifying the system in depth.
For the reactor to work at the start, you have to heat it drastically, use river water or hard water from a well, so that the rod is covered with insulation.
operates the bubbler with low water level.
Be patient before thinking that the assembly is not good, it may take some time to walk to get performance.
On a turbo diesel it is advantageous to put insulation on the reactor and the bubbler especially for walking at 100kmh
temperatures will change
it is different from a tractor that moves slowly and that the engine forces, an auto it sells strongly under the hood and the engine does not force at 100kmh.
Walk the bubbler with low level.
Beautiful editing
- Wonder TITI
- I learn econologic
- Registration: 07/03/06, 11:56
I agree with you, I am looking for a simple and effective solution but if possible without putting the tank under pressure.Andre wrote: The water level control will be chaotic because of the pressurization of the bubbler with the turbo.
And then the bubbler is not always under pressure, I am not at all times On a normal course, we decelerate very often, it is in these moments that I want to fill. Obviously, on the highway it is not easy to think of decelerating to fill the bubbler!
Well for depression, it's not possible! I am going to put a snorkel which pushes the air in the filter which itself has a low resistance.Andre wrote:It would have been preferable to make a simple air vent for the bubbler and let the engine slip through the bubbler
It would therefore require a venturi but what bothers me with a venturi is the restriction (loss of power) and when I'm stuck in clay, I need all my watts!
Also, I found (at oral pressure ) that air circulates very difficultly through the reactor that's how it is for you too
I wonder if it's as effective to suck with a venturi as to push with a turbo
Andre wrote:Let's say that your assembly is well designed, as well as the layout as the manufacturing, you can easily make minor changes, without modifying the system in depth.
thank you. On your part, it's nice.
Ah, I was collecting water from a dehumidifier to put in the bubbler. The water in my house is very limestone (c lousy champagne!), It will do the trick, right?Andre wrote:For the reactor to work at the start, you have to heat it drastically, use river water or hard water from a well, so that the rod is covered with insulation.
Ah, I can not put too much insulation because it is an all terrain vehicle is often dirty down to its smallest corners, and wash at high pressure!Andre wrote:..On a turbo diesel it is advantageous to put insulation on the reactor and the bubbler especially for walking at 100kmh
I try to maintain a low level in the bubbler, but with my pressure, it's not obvious ...
Thank you André for your comments
My 4x4, I treat it so that it pollutes less: the oil in the reservoir and the water vapeure admission !!!
- Similar topics
- Replies
- views
- Last message
- 41 Replies
- 54077 views
Last message by Flytox
View the latest post
28/02/14, 18:43A subject posted in the forum : Water injection in engines: montages and experiments
- 4 Replies
- 15998 views
19/11/13, 22:03A subject posted in the forum : Water injection in engines: montages and experiments
- 8 Replies
- 11304 views
20/05/10, 22:46A subject posted in the forum : Water injection in engines: montages and experiments
- 25 Replies
- 23872 views
Last message by Other
19/03/10, 03:11A subject posted in the forum : Water injection in engines: montages and experiments
- 0 Replies
- 7869 views
Last message by F4AGL
07/12/09, 20:42A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 120 guests
