Hello
Your flame safety, not sure it's a real thermo couple
Is it a rigid and waterproof copper pipe that comes out?
Most often the pipe does not contain 2 electric wires but a liquid. When it is heated its volume / pressure increases and switches a pressure switch.
This contact will more or less directly control the passage of the fuel.
Achieve its temperature probes
Reason is the madness of the strongest. The reason for the less strong it is madness.
Hello again
Not sure if I advanced the schimbilik with my explanations.
On the forum next, they seem to know the problem much better than I do:
http://forums.futura-sciences.com/thread146678.html
- I learn econologic
- Registration: 30/03/05, 09:27
Hello,
no it's a thermo couple, it's not a thermostat, the cable is a solid rigid cable
the thermocouple feeds an electromagnet coil (as explained on the Flytox link).
in fact, apart from the temperature range, does it change whatever the probe is type K or A to Z?
http://www.pagethib.be.tf Adapting a gas burner or oil to PMC
If I say no nonsense the difference comes from the sensitivity and the margin of error on the measurement.
For example, type S has a lower sensitivity than type K, so a small error on the measurement of the voltage will lead to a larger error on the temperature than with type K.
There are also stories of more or less linear temperature / voltage curves.
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 124 guests
