Hello, I have to explain to children how to extract hydrocarbons after drilling. Then I say: "Once the production wells have been drilled, the hydrocarbons often spurt to the surface. A system of valves called a" Christmas tree "makes it possible to regulate their flow. The hydrocarbons are conveyed by underground or aerial pipes to a separation station. There we separate the oil and gas and then each is sent to its destination "(I also plan to talk about the pendulum pumps).
I admit that I myself have great difficulty in understanding the subject which is complex. If anyone could help me.
Thank you
Catouni
How do we extract hydrocarbons
- Capt_Maloche
- Moderator
- Registration: 29/07/06, 11:14
- x 42
"Consumption is similar to a search consolation, a way to fill a growing existential void. With, the key, a lot of frustration and a little guilt, increasing the environmental awareness." (Gérard Mermet)
OUCH, OUILLE, OUCH, AAHH! ^ _ ^
It's a pretty huge subject.
If you want to talk about extraction, you may also approach prospecting ...
And then there are several extraction techniques whether on land or at sea (off shore) depending on whether the water table is under pressure and according to the quality of the hydrocarbon.
The deposits can contain gas, light, heavy hydrocarbons, bitumens ... and even tar sands.
Finally, many deposits reach exhaustion and the extraction methods are adapted to extract the heavy hydrocarbons which still remain.
The extraction methods vary according to the depth and nature of the soil ...
- Capt_Maloche
- Moderator
- x 42
Yep, our friend Wiki already says a lot, especially a history
http://fr.wikipedia.org/wiki/P%C3%A9trole
In general, at the start of extraction, oil spurts out under pressure.
When we reach the end of the life of the oil well: to extract everything that can be extracted, we inject water into the oil pocket. This, because it is heavier than the crude is deposited at the bottom.
If the injected water is under pressure, the oil output flow remains constant.
Bagnoles burn in the suburbs, it is after all only of self-destruction:
- Similar topics
- Replies
- views
- Last message
- 32 Replies
- 19554 views
Last message by dedeleco
View the latest post
16/10/11, 15:28A subject posted in the forum : Fossil fuels: oil, gas, coal and nuclear electricity (fission and fusion)
- 0 Replies
- 2397 views
Last message by jonule
20/06/08, 10:48A subject posted in the forum : Fossil fuels: oil, gas, coal and nuclear electricity (fission and fusion)
Go back to "Fossil energies: oil, gas, coal and nuclear electricity (fission and fusion)"
Who is online ?
Users browsing this forum : No registered users and 323 guests
