Bonjour à tous
This week I did a second venturi using the boilermaker method. I remind you that I only have a straight part of 50 mm for a diameter of 55 mm of hose.
Having taken a tube with an inner diameter of 27mm this gives me a venturi with very large attack slopes if it does not work as a venturi it should still create a pressure drop which I hope will be sufficient. The assembly as soon as the weather and the rest allow it.
https://www.econologie.com/fichiers/partager/Venturi3.jpg
https://www.econologie.com/fichiers/partager/Venturi4.jpg
https://www.econologie.com/fichiers/partager/Venturi5.jpg
Pantone mounting on Express F8Q D710
Hello
My last venturi on the Mercedes 300D turbo
the conduit is 63 mm in diameter the narrow passage of the venturi is 32mm, the rubber conduits the 62 mm is more for less
suction exceeds 1 meter (a water column) at 3500 rpm
the loss of speed is negligible, only at high speed
the turbo is more sibilant at high revs that makes the truck, probably it turns a little faster lack of air
André your 300D do what a cubic capacity
good evening everyone
I think that 27 mm of passage for a hose of 55 mm should make a sufficient pressure drop. The F8Q engine is not 2 liters, André your 300D does what displacement
Anyway I will mount this accessory this weekend, I will be fixed on efficiency.
Less consumption is good
Less pollution is already a great result
code: Select all
Je pense que 27 mm de passage pour une durite de 55 mm devrais faire une perte de charge suffisante. Le moteur F8Q ne fait pas 2 litres, André ton 300D fais quelle cylindrée
3 liters, I relied on the diameter of the turbo just in front of the turbine
I did not dare to pierce the aluminum venturi turbo inlet, like Michel ..
engine drank water
Hello everyone
The pseudo venturi recently mounted
https://www.econologie.com/fichiers/partager/VenturiDurite1.jpg
in the hose
https://www.econologie.com/fichiers/partager/VenturiDurite2.jpg
not yet giving me a vacuum, I introduced a tube cut in half lengthwise to create a greater pressure drop. Depression has become sufficient and even more than sufficient; the engine has been drinking water.
During the first tests during a gradual rise in speed, the engine got a little run over to choke better when it drank the cup.
Given the observation of his small tests, I still have to calm the bubbling to no longer have these liquid lifts.
To be continued in the next episode.
in the hose
I remain loyal to the bubbler
Bonjour à tous
I remain faithful to the bubbler but as this one has trouble rising in temperature (70 °) I considered adding a GV to it.
So here you follow me well I keep the bubbler and in fact the GV should be grafted on the bubbler; gain in temperature and heating time.
So here is the object (abstract art) to graft on my exhaust.
https://www.econologie.com/fichiers/partager/GV1.jpg
https://www.econologie.com/fichiers/partager/GV2.jpg
https://www.econologie.com/fichiers/partager/GV3.jpg
https://www.econologie.com/fichiers/partager/GV4.jpg
The object is to be welded after cutting a window in the exhaust tube.
The bubbler will have the role of preheating the water, stilling chamber, condensa (by default) and adding the necessary air.
Re: Pantone mounting on Express F8Q D710
Hello Rolcopter
Excuse me for going back on your post.
Since we have the same engine, your intake manifold is like this:
https://www.econologie.com/fichiers/partager/collect.JPG
The air arrives from the right in the photo and feeds the cylinders 1 3 4 2 (over time).
It seems to me that this arrangement of steam coming from the middle will only supply cylinders 3 and 4 well.
Moderately supply cylinder 2.
And badly supply the cylinder 1 (circuit against the flow of the air column coming from the air filter).
In short the 4 cylinders do not drink the same soup.
For those who have tried various positioning of this stitching, is it negligible or important?
RolCopter wrote:Connection of the reactor outlet on the degassing nozzle (engine block) in the middle of the manifold
https://www.econologie.info/share/partag ... ment2T.jpg
Reason is the madness of the strongest. The reason for the less strong it is madness.
there is a pressure effect
Bonjour à tous
To respond to Flytox, the tapping in the middle of the collector is suitable for engine degassing recycling which enters under pressure because as I had indicated (the one where you saw the photo) at this location there is a pressure effect which prevents any reactor recovery.
http://w10.frontsrv.com/forum/mes_Topic_3191128_1.html
I recycle in arboriculture.
Bonjour à tous
This is the result of the GV transplant on the exhaust tube; With all these departures from the branches, I hope to harvest fruit soon, or else I recycle myself in arboriculture.
https://www.econologie.info/share/partag ... nt14tx.jpg
https://www.econologie.info/share/partag ... ment12.jpg
https://www.econologie.info/share/partag ... ment17.jpg
A thought to all the other grafters and other doctors in perfusions for Heat engines.
- Similar topics
- Replies
- views
- Last message
- 41 Replies
- 54240 views
Last message by Flytox
View the latest post
28/02/14, 18:43A subject posted in the forum : Water injection in engines: montages and experiments
- 4 Replies
- 16030 views
19/11/13, 22:03A subject posted in the forum : Water injection in engines: montages and experiments
- 8 Replies
- 11319 views
20/05/10, 22:46A subject posted in the forum : Water injection in engines: montages and experiments
- 25 Replies
- 23925 views
Last message by Other
19/03/10, 03:11A subject posted in the forum : Water injection in engines: montages and experiments
- 0 Replies
- 7881 views
Last message by F4AGL
07/12/09, 20:42A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 67 guests
