Hello
Small panton assembly that works multi-fuel.
1 air intake control valve
2 engine power control valve
3 needle valve carburetor richness control
4 reduces 1 / 2 to 1 / 4 pipe
5 Carburetor
6 1 / 2 pipe cap
7 venturi for suction in the reactor
8 reactor rod 12, 7mm
9 anteroom
10 relaxation room in the hottest part
The rod is made of 12 steel, 7mm in diameter 260mm length
The play in the reactor approximately 1mm
it has 3 welding points at the entry which is rounded, the exit is cut square without centering point it has a rod of 3 mm screwed in the center and which ends with an eyelet supported in the cap, this allows its extraction easily and that keeps her positioned.
The tube reactor of 1 / 2 threaded pipe at the ends
the 1 inch pipe exhaust pipe casing to be welded to the reactor, two 1 / 2 pipe fittings are welded for exhaust inlet and silent outlet.
All elements are screwed with elbows and T plumbing
All conduits are in 1 / 2 pipe targeted
1 and 2 valves are ball valves
the 7 venturi is used to increase the depression in the reactor
The body of the reactor shell is screwed onto the cylinder head and must be thermally insulated.
The silencer comes from a mower it is screwed on the body of the reactor 1 / 2 pipe
The 4 cast iron reducer and to receive the carburetor
The fuel is sucked in at a height of 200 mm and the flow is controlled by a small needle valve
The carburetor is a simple brass fitting of 1 / 4 pipe, we drill a hole with a wick sharpened at 30 degrees and the outlet with a wick sharpened at 7 degrees, the reduced passage makes 4 mm, in this reduced we weld a small tube of 3,2mm with a Bic tip from which the ball has been eliminated, the carburetor is ready
Start-up
we start with petrol
we open the needle valve slightly
we close the 1 valve completely, we open the 2 valve to 100%
we start the engine, once running at the start it is rich
once warmed up, the 1 valve is quietly opened and the richness is reduced by the 3 needle valve
Once the reactor is hot, to increase the power
enriched by the needle screw then slowly open the 1 valve to work at the right ratio.
this operation can be done gradually until the full power of the engine.
At this stage you can control the power only by the 2 valve.
Once the engine is hot you can interchange the fuel pot with fuel oil or alcohol, without stopping the engine just changing the flexible jar duct. and readjust the richness, to the mazot little difference, to the alcohol it is necessary to enrich especially if it diluted with water.
when the reactor is operating well you can touch the muffler with your bare hands.
You can also walk with water and alcohol mixtures
We can on the inlet of the 5 carburetor suck water vapor in small quantity, either from a fogger or a bubbler heated with the exhaust or another water inlet opposite that of gasoline in the same small carburetor the water must be heated, it tends to cool the reactor (although the water in this small engine does not bring much efficiency in the same reactor a slight depletion when I enter the vapor in weak quantity in front of the carburetor)
This small motor starts with an electric motor of 0,5 CV once running this motor becomes generator the load it is two lamps of 100watt. The tests are done by measuring with the same load the time to consume a jar of 0, 5 liter of different fuel, all tests were done by comparison.
Plan a small engine 100% pantone multifuel
- Registration: 12/01/07, 08:18
- x 4
Re: Plan of a small 100% pantone multi-fuel engine
Andre wrote:Hello
Gently, André, one thing at a time
Now I'm going to rest a bit; the burner works automatically.
But the idea of multi-fuel is interesting.
See you soon
Alain
Hello
This little assembly is useless just to learn and try to understand, to make different tests with different rod
different fuel and summary consumption measures
let it run in the oil garage it heats the garage in the fall, it's an old 4 mount .. that I don't run often ..
just check when a guy on the net claims to have a nickel rod or different gap solution I pass it back to the tests ..
I will prepare another plan on the Chevrolet gasoline water doping.
you must avoid transposing the experience acquired from an 100% panton on water doping, this makes me lose almost 2 years.
- Similar topics
- Replies
- views
- Last message
- 21 Replies
- 32718 views
Last message by dede2002
View the latest post
17/02/14, 21:05A subject posted in the forum : Water injection in engines: montages and experiments
- 13 Replies
- 14240 views
Last message by Christophe
06/01/09, 00:58A subject posted in the forum : Water injection in engines: montages and experiments
- 13 Replies
- 55064 views
Last message by Flytox
16/01/17, 23:06A subject posted in the forum : Water injection in engines: montages and experiments
- 1 Replies
- 3624 views
20/11/06, 11:54A subject posted in the forum : Water injection in engines: montages and experiments
- 51 Replies
- 71439 views
Last message by dog head
11/11/06, 12:10A subject posted in the forum : Water injection in engines: montages and experiments
Back to "Water injection in the engines: the assembly and experimentation"
Who is online ?
Users browsing this forum : No registered users and 144 guests
